14b on log manifold w/ 38mm tial?
Old Dec 14, 2005 | 03:53 PM
AbitAvenger's Avatar
Default 14b on log manifold w/ 38mm tial?
I have a 14b (td05h) that was just rebuilt, but is missing the internal wastegate. I was wondering if I could just run that turbo on a log manifold with a Tial 38mm w/ a 9psi spring with no problems?
Old Dec 14, 2005 | 04:32 PM
Old Dec 14, 2005 | 04:53 PM
zeroice's Avatar
Default Re: (AbitAvenger)
yea you can
Old Dec 14, 2005 | 05:02 PM
Do I have to do anything with the flapper that the actuator arm connects to or can I just leave it alone?
Old Dec 14, 2005 | 05:21 PM
jlacoy82's Avatar
71.192.16.183
Make sure to upgrade the womulator shaft if you're going to go with the external wastegate.
Old Dec 14, 2005 | 05:38 PM
Default Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to upgrade the womulator shaft if you're going to go with the external wastegate.
I'll make sure to do that
Old Dec 14, 2005 | 05:51 PM
CoreyR's Avatar
you need to seal the wastegate flapper whether you weld it shut or make a solid arm that holds the lever shut either way it needs to stay shut otherwise it will just bypass exhaust and you wont make much if any boost.
Old Dec 14, 2005 | 05:53 PM
Default Re: (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">you need to seal the wastegate flapper whether you weld it shut or make a solid arm that holds the lever shut either way it needs to stay shut otherwise it will just bypass exhaust and you wont make much if any boost.</TD></TR></TABLE>
That's what I thought, Thanks
k9n
Feb 3, 2009 05:09 PM
Ak_ef9
Dec 30, 2006 09:04 AM
simplegreenmachine
Apr 6, 2006 11:19 PM
1RMDave
Nov 16, 2004 02:17 PM
