Bleeding ITR brake system
Old Mar 16, 2002 | 08:48 AM
Eric R's Avatar
Default Bleeding ITR brake system
What's the right way to bleed my brake system and what amount of new brake fluid should I buy, enough to bleed the whole system. Good brand/type or good alternative.
- need to pass inspection for upcomming event -
thanks!
Old Mar 16, 2002 | 09:06 AM
FAST4DR's Avatar
Default Re: Bleeding ITR brake system ('01ITR#950)
Pick up a container of ATE. It has always done well for me. As for bleeding, grab a friend to depress the pedal while you open and close the bleeder screw. Simple as that. You should be able to bleed out the entire system of stock fluid with one liter of fluid. Have fun!
Old Mar 16, 2002 | 09:09 AM
Eric R's Avatar
Default Re: Bleeding ITR brake system (FAST4DR)
Any special precaution with the ABS system or it is just like bleeding any other earlier model car?
Old Mar 16, 2002 | 09:18 AM
FAST4DR's Avatar
Bleed away!
Old Mar 16, 2002 | 10:05 AM
ITR00-816's Avatar
New User
Do a search in the Archived Topics of the Tech board, there some good threads on the subject. I could have listed them for you, but you have to practice your search abilities
The ABS oil is in a different system than the brake oil. It a different procedure to bleed the ABS system
Old Mar 16, 2002 | 10:21 AM
Eric R's Avatar
Default Re: Bleeding ITR brake system (ITR00-816)
So, I understand the brake circuit is independent from the ABS mechanism and proceed to bleed like a regular system.
Thank guys!
Old Mar 16, 2002 | 10:22 AM
D's Avatar
D
yeah, don't listen to that comment.
bleeding sequence is LF, RF, RR, LR. Plastic mallet banging on caliper helps get out stubborn air bubbles. don't be afraid to wack the **** out of it.
D
Old Mar 16, 2002 | 10:33 AM
Eric R's Avatar
Default Re: Bleeding ITR brake system (D)
Good tips!
Thank you D
Old Mar 16, 2002 | 10:59 AM
ITR00-816's Avatar
New User
D
Can you elaborate please the
Because I still think the ABS oil and Brake oil don't mix, so if I'm wrong I would like to have more detail than just an
Peace
Old Mar 16, 2002 | 07:41 PM
bus stop's Avatar
What are you talking about
A car with ABS will just take a little more time to bleed the brake system.......there's no such thing as " ABS oil "
Old Mar 17, 2002 | 05:46 AM
Eric R's Avatar
Default Re: Bleeding ITR brake system (George Knighton)
Yeah, I have a Snap-on plastic mallet in my toolbox but, also have a 10 lbs. sledge hammer. Will that work better to get the stubborn air bubbles out the caliper???
Ja ja...J/K
Old Mar 17, 2002 | 05:51 AM
Cosworth's Avatar
Default Re: Bleeding ITR brake system (the real steve c)
where can I buy some of this magical ABS oil?
Come on, Steve... you know that it comes with the blink fluid!!!
Old Mar 17, 2002 | 08:53 AM
Jason's Avatar
D
I can see this in D's doctorate thesis for one of his classes
Old Mar 17, 2002 | 09:52 AM
BSQ's Avatar
BSQ
I think he may be referring to the '94-'97 non-Type-R Integras. They do have a seperate ABS brake fluid reservoir and the ABS system has to be bled seperately. All Type-R's and all 98+ Integras have a different ABS system which shares the brake fluid and does not require any different bleeding process.
BTW, my Helms manual ('94) indicates that the bleeding sequence is: RR, LF, LR, RF. I'm not sure if later manuals ('98+) suggest a different bleeding sequence.
Old Mar 17, 2002 | 11:19 AM
D's Avatar
D
Default Re: Bleeding ITR brake system (BSQ)
It does.
i97supratti
Apr 9, 2011 10:42 AM
__oversea
Jul 6, 2008 07:51 AM
HalfAnP
Mar 18, 2005 10:41 PM
krshultz
Nov 16, 2003 12:59 AM
