b17 GSR Oil Pump For LS/Vtec Setup
Old Dec 14, 2005 | 05:55 AM
Topdawgg's Avatar
Default b17 GSR Oil Pump For LS/Vtec Setup
Can this be used... anyone know?
Old Dec 14, 2005 | 06:52 AM
RobbieG35's Avatar
12 Years Strong
Default Re: b17 GSR Oil Pump For LS/Vtec Setup (Topdawgg)
What year car is it going in?
Old Dec 14, 2005 | 11:08 AM
Topdawgg's Avatar
I dont think that would matter AT ALL... but its a 93..
Old Dec 14, 2005 | 11:14 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">I dont think that would matter AT ALL... but its a 93..</TD></TR></TABLE>
A B17 GSR would work - Yes it does matter - OBD2 cars require different oil pumps. OBD2 cars have the crank angle sensor built into the oil pump assembly. Check a part number for a 95 GSR oil pump, and then check ir for a 96 GSR oil pump and it is different. - I had to find that out the hard way. OBD1 pump on an OBD2 car = Crank angle code
Old Dec 14, 2005 | 11:18 AM
Hybrid96EK's Avatar
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
A B17 GSR would work - Yes it does matter - OBD2 cars require different oil pumps. OBD2 cars have the crank angle sensor built into the oil pump assembly. Check a part number for a 95 GSR oil pump, and then check ir for a 96 GSR oil pump and it is different. - I had to find that out the hard way. OBD1 pump on an OBD2 car = Crank angle code</TD></TR></TABLE>
Its not "built in", but the housing is cast different to allow the use of the CPS.
Old Dec 14, 2005 | 11:57 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Its not "built in", but the housing is cast different to allow the use of the CPS.</TD></TR></TABLE>
There ya go.
Old Dec 14, 2005 | 12:01 PM
LSTEG96's Avatar
Its not "built in", but the housing is cast different to allow the use of the CPS.</TD></TR></TABLE>\
CFK
Old Dec 14, 2005 | 12:47 PM
Topdawgg's Avatar
correct me if im wrong, but the b17 GSR motor only came in 92-93 GSR's... therefore, arent all b17's obd1.?
Old Dec 14, 2005 | 01:52 PM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but the b17 GSR motor only came in 92-93 GSR's... therefore, arent all b17's obd1.?</TD></TR></TABLE>
Yes. I just needed to know if your car was OBD1 or OBD2.
Old Dec 14, 2005 | 01:55 PM
Topdawgg's Avatar
ok cool, yea.. the car is using a p28.. its obd1..
So i can use this b17 oil pump, or should I just buy a new b18c Gsr pump?
Old Dec 14, 2005 | 01:56 PM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">ok cool, yea.. the car is using a p28.. its obd1..
So i can use this b17 oil pump, or should I just buy a new b18c Gsr pump?</TD></TR></TABLE>
Is the B17 pump brand new? Are you putting a new motor together?
Old Dec 14, 2005 | 02:00 PM
Topdawgg's Avatar
its a used b17 pump from a block I picked up..
should i just buy a new one instead? Or are used pumps ok?
Dave_Dc2
Jun 8, 2009 10:25 PM
street_ride14
Sep 25, 2008 04:27 PM
Tom123456
Apr 21, 2007 07:12 AM
92integraVTECgsr
Mar 17, 2006 06:25 AM
hbkxtbone
Jan 5, 2005 04:12 PM
