b17 GSR Oil Pump For LS/Vtec Setup
12 Years Strong
Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">I dont think that would matter AT ALL... but its a 93..</TD></TR></TABLE>
A B17 GSR would work - Yes it does matter - OBD2 cars require different oil pumps. OBD2 cars have the crank angle sensor built into the oil pump assembly. Check a part number for a 95 GSR oil pump, and then check ir for a 96 GSR oil pump and it is different. - I had to find that out the hard way. OBD1 pump on an OBD2 car = Crank angle code
Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">
A B17 GSR would work - Yes it does matter - OBD2 cars require different oil pumps. OBD2 cars have the crank angle sensor built into the oil pump assembly. Check a part number for a 95 GSR oil pump, and then check ir for a 96 GSR oil pump and it is different. - I had to find that out the hard way. OBD1 pump on an OBD2 car = Crank angle code</TD></TR></TABLE>
Its not "built in", but the housing is cast different to allow the use of the CPS.
12 Years Strong
Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Its not "built in", but the housing is cast different to allow the use of the CPS.</TD></TR></TABLE>
There ya go.
There ya go.
Re: (Hybrid93Eg)
Its not "built in", but the housing is cast different to allow the use of the CPS.</TD></TR></TABLE>\
CFK
CFK
12 Years Strong
Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but the b17 GSR motor only came in 92-93 GSR's... therefore, arent all b17's obd1.?</TD></TR></TABLE>
Yes. I just needed to know if your car was OBD1 or OBD2.
Re: (HybridHatch88)
ok cool, yea.. the car is using a p28.. its obd1..
So i can use this b17 oil pump, or should I just buy a new b18c Gsr pump?
12 Years Strong
Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">ok cool, yea.. the car is using a p28.. its obd1..
So i can use this b17 oil pump, or should I just buy a new b18c Gsr pump?</TD></TR></TABLE>
Is the B17 pump brand new? Are you putting a new motor together?
street_ride14
09-25-2008 04:27 PM
92integraVTECgsr
03-17-2006 06:25 AM
