Fixing broken oem ITR injector
Old Dec 14, 2005 | 02:10 AM
Ax3l's Avatar
Default Fixing broken oem ITR injector
Hey.
I got a set of 4 240cc obd2 ITR injector in the mail to use on my b16a2 swap. Only problem is that one of the injectors was damaged.
(The pic is not of the actual injector...)
The plastic part in the red ring was broken on one of my injectors. (The piece is hard brown plastic on the ITR injectors) I was wondering if it is some way of fixing that? Could i just swap the broken piece with a piece from a 240cc d16z6 or 240cc b16a2 (obd1) injector? I've got a few in the garage. Is it glued on or something?
Or do i have to get a new injector?
Any R techs wanna help me out?
-Thanks
Old Dec 14, 2005 | 02:52 AM
Reid's Avatar
Global Moderator
Default Re: Fixing broken oem ITR injector (Ax3l)
Just use ANY B or D series OBD2 Honda injector.
Old Dec 14, 2005 | 03:14 AM
Ax3l's Avatar
Default Re: Fixing broken oem ITR injector (Reid)
Yeah, but i only have obd1 injectors.
Sooo... i bought a set of obd2 itr injectors and one broke... Soooo... i need help with my questions.
I know i can swap connectors and use obd1 injectors, i know i can buy a new itr injector, i know all that.
But can the broken ijector be fixed?
Old Dec 14, 2005 | 03:19 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ax3l &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, but i only have obd1 injectors.
But can the broken ijector be fixed? </TD></TR></TABLE>
Purchase another set of used OBD2 Honda B/D series injectors. It can't cost much at all.
There's no point trying to fix a broken injector. It is simply not worth the risk, IMHO.
Old Dec 14, 2005 | 03:29 AM
Ax3l's Avatar
Aww... oh well...
So it's not possible to just swap the broken part over from a obd1 b-series injector?
Old Dec 14, 2005 | 03:47 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ax3l &raquo;</TD></TR><TR><TD CLASS="quote">So it's not possible to just swap the broken part over from a obd1 b-series injector?
You're free to do whatever you want to save money.
Personally, I wouldn't risk ruining the spray pattern of one of my injectors. They're a fairly important part of the engine.
Old Dec 14, 2005 | 03:55 AM
Ax3l's Avatar
Know if/where i can get a single injector then?
Or maybe ill just use my obd1 injector then and cut the connectors off my harness.
Old Dec 14, 2005 | 07:21 AM
PM-Performance's Avatar
Anyone should work.
I have a set of my ITR injectors laying around though if you need replacements.
Make offer if you need them
Old Dec 14, 2005 | 08:29 AM
migs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">You're free to do whatever you want to save money.
Personally, I wouldn't risk ruining the spray pattern of one of my injectors. They're a fairly important part of the engine.</TD></TR></TABLE>
I agree with Reid. It ISNT worth the risk of having the wrong spray pattern. A NEW OEM Injector will run you $125+ per.
Old Dec 14, 2005 | 10:12 PM
Ax3l's Avatar
Know where i can get them one by one, and not in sets of four?
Old Dec 14, 2005 | 10:57 PM
uNF$@#!'s Avatar
Default Re: (Ax3l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ax3l &raquo;</TD></TR><TR><TD CLASS="quote">Know where i can get them one by one, and not in sets of four?</TD></TR></TABLE>
1) you sound like a broken record
2) if youre that tight on cash/stingy then this car modding thing...just isnt a good thing for you.
Old Dec 15, 2005 | 01:59 AM
00-501itrspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">There's no point trying to fix a broken injector. It is simply not worth the risk, IMHO.</TD></TR></TABLE>
yea seems liek fuel delivery would be important , unless you have the proper tools to see if the injector is working and spraying properly , i wouldnt stick it in my motor just mt .02 cents
Old Dec 15, 2005 | 04:03 AM
Ax3l's Avatar
No need to buy 4 if i only need 1.
And it was all just an idea about fixing it. Ill just use the obd1 set og get a new set of obd2. No worries.
Ah, never mind then. Thanks for the help guys.
Old Dec 15, 2005 | 05:50 AM
businessman_b's Avatar
^ I don't think that's entirely accurate....they're all 240cc.
In response to the question, I agree with the masses....it may be possible to repair the broken one, but it's much faster and easier to just find yourself a replacement.
Old Dec 15, 2005 | 06:28 AM
Default Re: (businessman_b)
For the money you will spend on one replacement you can buy ALL of my low milage ones and be done with it. have extras in case. I would keep them, but I sold off all my Hondas and have no use for 240CC's. If they were 550's-1000's I could use them. lol
$50 shipped and you can have them all. 20k miles on them if that
Old Dec 15, 2005 | 01:25 PM
vtec.dc2's Avatar
as mentioned, at least 92+ civics and 94+ integras had 240's.. difference is in fuel pressure.. so, in a way, by getting civic injector you're getting something that went through less
on top of whats already said, if i'm to buy used injectors, i'd send them for balancing and cleaning to make sure they work.
ludedeg's Avatar
I have a set of obd2 injectors and clips for cheap https://honda-tech.com/zerothread?id=1454007.
killerpenguin21
May 2, 2010 11:51 AM
Turbo_y8
Jan 20, 2006 09:19 PM
Ax3l
Dec 13, 2005 11:33 PM
B18 CYA
Jun 23, 2004 04:15 PM
Black R
Jun 17, 2004 01:34 AM
