Buiding a 2.0l JDM B18c
Old Dec 13, 2005 | 04:18 PM
1337 Si's Avatar
Default Buiding a 2.0l JDM B18c Need insight
Ok, I have this motor on my porch and it has been sitting there for nearly 6 months. I was considering boosting the b16 in my EM1 but I think for all around fun and drivability a 2.0l b18c would be the most overall fun. I planned on getting GE sleeves, 84mm CP 12:1 comp pistons and still am undecided on the rods. I was also going to use my present b16 head and have it ported by Portflow and add in some Skunk2 cams to the mix. This is also my daily driver that will be driven 80 miles a day. Now, my questions:
1. Would 440cc injectors be enough to run this AND net about 200-220whp?
2. Should I lighten the crank at all or is it good the way it is?
3. Neptune best ECU option?
Any insight on info pertaining to this build would be greatly appreciated. If I am leaving anything out ask me a question and I will happily respond.
Modified by 1337 Si at 7:50 PM 12/13/2005
Old Dec 13, 2005 | 06:54 PM
1337 Si's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (1337 Si)
TTT, comon somone has to know something to help me.
Old Dec 13, 2005 | 07:00 PM
mikesrex's Avatar
440's are more than enough for that WHP range. You may actually be ok with 310's
I would just run a stock crank unless you can get a good deal on lightening and balancing.
Neptune is a good option, but so is Hondata and Crome
Old Dec 13, 2005 | 07:11 PM
PyroProblem's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (mikesrex)
440's are plenty...I run 370's in my d.d.
Id leave the crank stock, maybe just micropolish the journals...
Eagle makes nice rods and theyre affordable too...
2.0 gsr's are FUN on the street. The mid range TQ and throttle response will keep you grinning the way to work everyday. It does me!
Get whatever your tuner is most familiar with. Any system will work to maximize your engines capabilities,its really if you want to tune yourself or have extra options that will help you decide.
Old Dec 13, 2005 | 07:51 PM
1337 Si's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (PyroProblem)
Thanks for the responses guys. DO you think sleeving it is overkill? Also I had anticipated on having SuperDave tune the bitch. Oh, in regards to a header, Hytechs street header sound good?
Old Dec 13, 2005 | 09:29 PM
1337 Si's Avatar
TTT
Old Dec 13, 2005 | 09:31 PM
WhoDoYouThink's Avatar
hytech good ****!! i plan on getting one in the next month or on my 12:1 gsr
Old Dec 13, 2005 | 09:33 PM
1337 Si's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (2000turbogsr)
What is the cost on the street header and I cant seem to find their homesite.
Old Dec 14, 2005 | 12:13 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337 Si &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the responses guys. DO you think sleeving it is overkill? Also I had anticipated on having SuperDave tune the bitch. Oh, in regards to a header, Hytechs street header sound good?</TD></TR></TABLE>
Sleeving may be overkill in the sense that you will likely not need the strength. But if you want 84+mm, you have no choice but to sleeve. As for the Hytech header, you cannot go wrong with it if you can afford it.
Old Dec 14, 2005 | 02:27 AM
fmrprojects's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (StorminMatt)
hmm b18 motor on the porch, where do you live? J/K nah the choices you have in mind are great for the set-up. good luck keep us posted
Old Dec 14, 2005 | 09:11 AM
1337 Si's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (fmrprojects)
Will do. I more than likely will be sending the bottomend to Earl to have Benson To their dirty work. There are places around here that can do it and that I hear are good but I still don't trust them. I had a b16 built for boost built by some shop here and they put too much clearancce between the pistons and sleeves, thus the motor always sounding like a TDI. Also the sleeves were completely scarred and you could move the pistons back and forth in the sleeve with your hand.
Where is Hytech's homesite?
Old Dec 14, 2005 | 09:34 AM
97L-esVeeTeg's Avatar
Where is Hytech's homesite?</TD></TR></TABLE>
http://hytechexhaust.com
Old Dec 14, 2005 | 10:12 AM
1337 Si's Avatar
Default Re: Buiding a 2.0l JDM B18c Need insight (97L-esVeeTeg)
Awesome, thanks!
bsmith100
Jun 5, 2009 01:07 PM
danb18c
Jan 26, 2005 01:43 AM
1hotcivicSi
12
Feb 15, 2004 10:37 AM
jaydmcrx
Oct 6, 2003 03:40 PM
ekekek
Feb 7, 2002 10:00 AM
