What size wrench should I use for:
Old Dec 13, 2005 | 10:51 AM
pentaq's Avatar
Default What size wrench should I use for:
an oil cooler nut and an oil pressure sensor?
H22 of course...
Metric please
Thanks
Old Dec 13, 2005 | 10:56 AM
Eddiebx's Avatar
Old Dec 13, 2005 | 10:57 AM
pentaq's Avatar
Default Re: (Eddiebx)
too small
besides this wrench is not precise and nut is sticking a bit only, so I don't want to strip it.
Old Dec 13, 2005 | 11:00 AM
kulrevon's Avatar
I could be way off. but 22mm comes to mind. 28?
edit see I was way off. the second one was a little closer.
Modified by kulrevon at 3:20 PM 12/13/2005
Old Dec 13, 2005 | 11:18 AM
Rosko's Avatar
Default Re: (kulrevon)
Its 30mm (oil cooler). I just measured mine to be sure. Make sure you get a deep socket. I used an axle nut socket cuz they are fairly cheap and available at most parts stores.
My pressure sensor is a 24mm and the base it screws into is 26mm
Old Dec 13, 2005 | 11:45 AM
pentaq's Avatar
Default Re: (Rosko)
Thanks a lot.
Old Dec 13, 2005 | 08:33 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
oh the mexican socket set....dammmmmmm
good info dude....
Old Dec 13, 2005 | 09:29 PM
Eddiebx's Avatar
that and this is all a messican ever needs
Old Dec 14, 2005 | 01:22 AM
pentaq's Avatar
forgot about the hammer
RSciviX
13
Apr 22, 2006 10:57 PM
Novtecdohc
Sep 4, 2005 01:10 PM
RACEPAK
17
May 19, 2005 04:53 AM
egizzle8
Mar 9, 2004 09:07 PM
pr0jektdc2
Oct 3, 2002 06:36 PM
