ls/vtec question
Old Dec 12, 2005 | 04:18 PM
91pearlcivic's Avatar
Default ls/vtec question
Im in the build of putting a ls/v together and i bought a gsr head i was told that it was a better head to use then the b16.They told me i would get more tourqe and whp out of this head.I was woundering if this was true.Also is p30 (2nd gen )b16 pistons to much commpression ratio for the streets. Thanks for the time
Old Dec 12, 2005 | 06:45 PM
onepoint6i's Avatar
Default Re: ls/vtec question (91pearlcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91pearlcivic &raquo;</TD></TR><TR><TD CLASS="quote">Im in the build of putting a ls/v together and i bought a gsr head i was told that it was a better head to use then the b16.They told me i would get more tourqe and whp out of this head.I was woundering if this was true.Also is p30 (2nd gen )b16 pistons to much commpression ratio for the streets. Thanks for the time </TD></TR></TABLE>
you'll gain a couple of points in compression with a GsR head so IMO a gsr head is a better choice, there is a difference in flow comparisons, but once its ported it doesnt matter...
P30 pistons will be a perfect choice for this build...just search a bit and you'll see good luck
Old Dec 13, 2005 | 10:56 AM
Default Re: ls/vtec question (onepoint6i)
thatnks for the imfo i will have pics and avideo in the spring
0930_SI
May 22, 2008 08:48 AM
hatchyAllday
Feb 27, 2008 04:02 AM
2gen_tegs_rule
Feb 6, 2006 12:29 PM
JDMbiAtcH
Aug 25, 2005 12:00 PM
raider099
Apr 11, 2005 03:16 AM
