Look at my plug
Old Dec 12, 2005 | 03:18 PM
JMod's Avatar
Default Look at my plug
Definetly looks like i'm running lean from the looks of my plugs, these have been in the car for about 20k now. I've got some motor work, Port n Polish, valvetrain, skunk stg 2 cams. I do have a adjustable FPR, but the car will be getting tuned via hondata in january. I think its about time to throw in a new set of plugs, the ones i have now are NGK Platinums (BKR6EGP). Should I just get a set of the same ones, or should I run a colder plug. Any help would be appreciated.
Old Dec 12, 2005 | 03:26 PM
98 Spec R's Avatar
Default Re: Look at my plug (JMod)
If you really want to know if you are running lean or rich, hook up a wideband O2 sensor to it. I would recommend that instead of trying to read your plugs. Your Hondata tuner will have a wideband O2 sensor.
Old Dec 12, 2005 | 03:28 PM
JMod's Avatar
Default Re: Look at my plug (98 Spec R)
Well yea I know that, but its not going to be tuned until probably the end of January. So i'm just gonna pick up a new set until then and hopefully get it running a bit smoother.
Old Dec 12, 2005 | 03:30 PM
SSBPGSR's Avatar
get one step colder than stock.
Old Dec 12, 2005 | 03:44 PM
JMod's Avatar
Default Re: Look at my plug (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">get one step colder than stock. </TD></TR></TABLE>
Which plugs would you recommend?
Old Dec 12, 2005 | 04:17 PM
JMod's Avatar
Anyone know what plug (part #) that would be one step colder than stock for a gsr?
Old Dec 12, 2005 | 04:25 PM
SSBPGSR's Avatar
ngk bkre7-11
Old Dec 12, 2005 | 09:56 PM
JDMorgan's Avatar
go with the normal ngk copper plugs, one step colder.
fitbmx86
10
May 22, 2007 06:39 AM
yz125rider21
Jan 17, 2006 03:54 PM
Na-Spirit
Mar 8, 2005 03:59 PM
Formula 1
May 15, 2003 11:22 AM
bronzehatch
Jul 22, 2002 02:14 PM
