dpfi to mpfi wiring for pm9 ecu with conversion harness"HELP"
i have a 91 honda civic hatchback and I need to know what to disconnect from my pm9 ecu so i can hook up my conversion harness.Need to know what to disconnect so I can plug up the conversion harness to the ecu.
one of my friends took the dpfi harness and went through and added the wires and plugs i needed for mpfi to work with a stock 91 civic ecu, but i need to know what to pull out of my stock ecu so i can add the new pins for the extra injectors and things to the ecu.
what do you mean plug your harness into the ecu..a dx to mpfi harness has 4 wires that run into the ecu plug and thats it..you also have to switch wires around at b10 and b12..injector #2 is A3 and injector #4 is A7..TDC and CRANK ANGLE are C1 and C2
put pins c1 into b10 and c2 into b12
take pins out from b2 and b11
solder a blu/grn wire to b2 and plug it into c1
solder a blu/yel wire to b11 and plug it into c2.
run injector wiring to #2 A3 and #4 A7.
some people like to run straight form the ecu to the dist and injectors, i dont like that because if you ever want to take the motor out with the harness youll run into alittle trouble. i put a connector at the passenger side shock tower to i could disconnect it if i want to.
the blu/grn goes to dist blu/grn
the blu/yel goes to dist blu/yel
switch and extend the tps wires around, you have to extend the iacv wires
oh and the resistor box if running obd0 injector, use the either the power wires from the injector clips or go to the drivers side shock tower and take the power wire from there. find continuity from the injector clips to whatever wire it is
i think thats it??
i think thats it??
Thats all i needed to know , Thanks that is a big help maybe know i can get this thing running so i can get it to the body shop. Thanks
One more Q's my gas pedal is stiff and wont move even with the throttle cable undone from the trottle body it still wont move. Anyone know why?
yeah, but i cant find anything. i think its something with the pedal and not the cable. it maybe froze up; i will look at it again closer and see if i can give you more details.
Chris1
Sep 14, 2008 09:43 AM
psycho.chicken
Jul 12, 2006 10:12 AM
