Will a B-20A-5(88-91)prelude crank fit into a B-20B/Z block ?
Old Dec 12, 2005 | 07:43 AM
AutoTrenz702's Avatar
Default Will a B-20A-5(88-91)prelude crank fit into a B-20B/Z block ?
I was wondering has this been done since the b-20a5 has a 95 mm crank ! Would it fit into a b-20b/z block ? Cause I've been told all the factory cranks are built very well and balanced from the factory! So instead of buying a $750 aftermarket 95 mm crank I wanted to try and use a factory honda b-series crank ! Thanks for any input you guys have on this !
Old Dec 12, 2005 | 10:39 AM
The_Head's Avatar
Default Re: Will a B-20A-5(88-91)prelude crank fit into a B-20B/Z block ? (AutoTrenz702)
I believe you can... I think I remember hearing a few years ago that Crower used the B20A cranks for their stroker kits.
bump for myth busters
Old Dec 12, 2005 | 12:18 PM
JohnnieChimpo's Avatar
Default Re: Will a B-20A-5(88-91)prelude crank fit into a B-20B/Z block ? (The_Head)
I have not done this but have searched it for a while on here.
What I came up with was there is machining to make it work properly. The oil pum[ drive is the wrong size and the thrust bearing is wrong but those things can be fixed. The problem is once you pay for that a $600 aftermarket isn't that much more money.
The other thing I found is a lot of people who have oil usage problems due to high wear in engines without a deck plate.
pokie
11
Jun 20, 2010 07:23 PM
victor.ek4
Jun 2, 2010 12:47 PM
Sci_v_icI
Apr 1, 2006 12:41 PM
1700anddroping
Dec 16, 2004 04:02 AM
Bnjmn
Jan 23, 2003 09:30 AM
