Do I need Camber Correction Kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesdaynightfever »</TD></TR><TR><TD CLASS="quote">Get an alignment and tell them to set your toe as close to factory spec as possible and call it a day. </TD></TR></TABLE>
Actually, you'll want it set to 0, not 'in spec'.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g »</TD></TR><TR><TD CLASS="quote">but if they cant get it to 0 then get a kit i use skunk2
</TD></TR></TABLE>Same here. S2 kit is nice.
-Red
</TD></TR></TABLE>Same here. S2 kit is nice.-Red
A camber kit won't help with toe correction. If they can't get the toe to 0, something is probably bent.
</TD></TR></TABLE>A camber kit won't help with toe correction. If they can't get the toe to 0, something is probably bent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">Actually, you'll want it set to 0, not 'in spec'. </TD></TR></TABLE>
My bad.
My bad.
Sorry if I sound stupid, but I new this the suspension setup. I want to make sure I do it right the first time.
So what everyone here is saying is...
"No, you don't need a camber kit, but make sure you get an alignment"
righT?
THanks
righT?
THanks
lol. Yes, do this and you're golden.
My civic is sitting on arospeed coilovers with a 3.5 in drop with no camber kit on stock steelies and my tires have very little inside tread wear at all, but if you have the money to buy a camber kit spend the extra pennies and invest in one it will probably save you in the long run but if you go 1-1.5 it wont hurt your tires much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mushu315 »</TD></TR><TR><TD CLASS="quote">Sorry if I sound stupid, but I new this the suspension setup. I want to make sure I do it right the first time.
righT?
THanks
Correct.
Just get an alignment and you will be set.
righT?
THanks
Correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">ive been lookin 2 buy either skunk2 or omni. i heard omni is better but not sure</TD></TR></TABLE>I've got skunk2 springs and camber kit and have had no problems thus far. Been installed since May.
-Red
-Red
i heard skunk2 and omni are made at the same factory... most likely the same ****... i got the skunk2 camber kit, its pretty cool. just remember if you get the original version to tighten down those alan nuts good. still gonna have to get it aligned whether you get the kit or not.
Mr.Saturn
Aug 10, 2004 08:41 PM
silverCRXTC
Jan 27, 2004 02:03 PM
