90crx SI 1.6 axle's
I have a 1990 crx SI 1.6 built 9/98. I am having a problem with my axles. I removed my old axles and whent to the local auto parts and exchanged them. they gave me Part # 44010-sj4-963. when I tried to install I noticed the inner joint was to short and the spline was also wrong on both l/h and r/h. When I went back to the store they gave me the same Part# axles. they also would not work. I tried sevral other auto parts and axle shops but they keep giving me the same part number shaft.
Thanks.
Modified by jetmech at 6:27 AM 12/14/2005
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetmech »</TD></TR><TR><TD CLASS="quote">I have a 1990 crx SI 1.6 built 9/98. I am having a problem with my axles. I removed my old axles and whent to the local auto parts and exchanged them. they gave me Part # 44010-sj4-963. when I tried to install I noticed the inner joint was to short and the spline was also wrong on both l/h and r/h. When I went back to the store they gave me the same Part# axles. they also would not work. I tried sevral other auto parts and axle shops but they keep giving me the same part number shaft. her is my vin # incase this may help
Thanks.</TD></TR></TABLE> You may want to remove the VIN #, safeties sake. Where exactly in Miami are you located? IDK what is going on with your axle craziness but for future reference ALWAYS compare the one you are exchanging with the one they are giving you.
raidacaipo
60
Sep 4, 2010 09:04 PM
