what are the best cams for turboing?
Old Dec 11, 2005 | 05:45 PM
97turboteg's Avatar
Default what are the best cams for turboing?
im wondering what cams i should get for my turbo acura integra ls, the whole bottom end is reinforced. I hear cams with big lobes are no good, they let exhaust back in. Should i get stage 1 after market cams, or should i keep the stock cams for the money?
Old Dec 11, 2005 | 06:10 PM
kntcdis's Avatar
stock cams is better for turbo
Old Dec 11, 2005 | 06:30 PM
DC4cedInducted's Avatar
Default Re: (cntcdis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cntcdis &raquo;</TD></TR><TR><TD CLASS="quote">stock cams is better for turbo</TD></TR></TABLE>
wrong.
Old Dec 11, 2005 | 09:01 PM
PrinceAli132's Avatar
Default Re: (DC4cedInducted)
» Search Results
Your search for turbo cams returned 257 results. In the FI forum only
» Search Results
Your search for turbo cams returned 24 results. In the integra forum.
I'm dont really know anything about this, but it seems to be have been covered extensively. Look into crower 402 or 403.
It might help others, if you tell us what kind of motor and some other details.i'm just tryin to help
Ali
Ali
Old Dec 11, 2005 | 10:03 PM
Thurman Merman's Avatar
moron, don't spread your incorrect thoughts.
I've seen people put down good #'s surprisingly with the crower 404s. They are "claimed" to be an NA cam, but when tuned right and the correct valvetrain, will make excellent power and still maintain a decent street driven idle.
I think BLOX just came out or has out turbo cams for the b18a/b. Check with BLOX, Crower, and Crane.
Old Dec 11, 2005 | 10:05 PM
cambopheonix56's Avatar
Default Re: (Thurman_Merman)
I think you need a cam with a longer duration and lower lift. Correct me if I am wrong.
Old Dec 11, 2005 | 11:26 PM
noahrexion's Avatar
I don't know of any B18 cams that will give a lower lift that stock... thats not a great idea
Old Dec 11, 2005 | 11:29 PM
Dartanian's Avatar
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">I think you need a cam with a longer duration and lower lift. Correct me if I am wrong.</TD></TR></TABLE>
You want high lift and short duration, ideally.
It seems like the rumor of running an N/A cam on a forced induction car as a bad idea has been proven wrong by many people. If you can get some of the overlap out with cam gear timing, you will make some great power with some high lift, long duration N/A cams.
Old Dec 11, 2005 | 11:42 PM
Default Re: (Das Schmoo)
Another question is what is your setup as of right now?
Old Dec 12, 2005 | 12:14 AM
1turbodc2's Avatar
my buddy shmoo is running CTR's in his car, and i am still running my GSR cams, but soon to change with either some turbo cams or CTRs
Old Dec 12, 2005 | 11:47 AM
Default Re: (gssr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gssr &raquo;</TD></TR><TR><TD CLASS="quote">my buddy shmoo is running CTR's in his car, and i am still running my GSR cams, but soon to change with either some turbo cams or CTRs</TD></TR></TABLE>
Which doesn't help this situation in the very least. You both have vtec heads, we are talking about LS turbo cams here. Did you read the first post?
Old Dec 12, 2005 | 02:34 PM
BrooX's Avatar
Old Dec 13, 2005 | 06:28 AM
97turboteg's Avatar
Default Re: (DA9GUY-637)
yeah man, were talkin non vtec, Im thinking about just like crower stage one's. I dont know, some ppl say go with stock, or almost stock, just not real lobey and others say go big. Maybe ill keep the stockers and go with head porting, and 3 angle valve job. Its around the same price. should i?
Old Dec 13, 2005 | 10:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman_Merman &raquo;</TD></TR><TR><TD CLASS="quote">Another question is what is your setup as of right now?</TD></TR></TABLE>
Old Dec 15, 2005 | 07:52 AM
97turboteg's Avatar
i took the engine out of my car to get bored. built with eagle rods, JE pistons, resurfaced head, valve job. and going to be installing my t3/t4 turbo after winter. im confused, some ppl say to stay with stock, and others say to go with good cams....
Natural Aspirations
Jan 19, 2011 05:01 PM
85mmek9
Oct 31, 2007 10:44 AM
EJ8 GSR-T
Jul 21, 2006 11:02 PM
smalls
Jul 11, 2006 03:55 PM
JasonNagra
Nov 5, 2001 09:30 AM
