shaft came apart inside the boot. how to fix
Old Dec 11, 2005 | 12:19 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default shaft came apart inside the boot. how to fix
i drove my car home put it in my garage and started to put my camber kit on today. well it came apart in the boot on the left side and i cant get it back to fit right what should i do. any special way?
Old Dec 11, 2005 | 12:38 PM
Lauj87's Avatar
if your lucky you can push it back..just have to becareful not to crush any bearings. but if you want to do it the safe way, just take the boot apart and put it back together..but its gunna take some time, CV boots are evil to me! hate dealing with them!
Old Dec 11, 2005 | 12:41 PM
Default Re: (Lauj87)
ive been tryin to get the damn thing in for like 2 hours
how do u get those clips off?
Old Dec 11, 2005 | 12:44 PM
Default Re: (stocker2shocker91)
is there some special method to push it back in?
this cursin up a storm out in my garage is making me mad. i am literally walkin to my garage and tryin what u guys say this keyboard is a greasy mess now, but i guess thats part of the experience
Lauj87's Avatar
ahahah once you get the clips off your gunna wish you never did, but all you need is a flat head. just slide it where it locks and bend it enough just so it loosens then use pliers or something to pry it lose. but putting it back on is where it's gunna **** you off!
Lauj87's Avatar
is this the driver side or passenger side?
Old Dec 11, 2005 | 12:45 PM
well damn i go give that a shot id rather be safe then sorry tryin to jam it in
Old Dec 11, 2005 | 12:46 PM
driver
Old Dec 11, 2005 | 12:48 PM
Lauj87's Avatar
if its the driver side then it'll be easier for you to take off the whole axle, there is a mount that holds the axle onto the engine, 2 14mm bolts take those out then the axle should slide right out the transmission, makes it alot easier.
Old Dec 11, 2005 | 12:50 PM
alright ill go see so should i do that then take the boot off?
Old Dec 11, 2005 | 12:52 PM
Lauj87's Avatar
yes, makes it alot easier putting it back on if you have a C clamp, and make sure when you put it back in your careful with it..because it could fall out again and **** you off! make you wanna kill someone!
Old Dec 11, 2005 | 01:03 PM
i couldnt get thos 2 boltss off i cant get a wrech or air powered wrech up there either
Old Dec 11, 2005 | 01:04 PM
wrench***
Old Dec 11, 2005 | 01:05 PM
can i just take the whole thing out out it back in then go from there
Old Dec 11, 2005 | 01:09 PM
why is it so hard to put back together in the first place, this is so frustrating
Old Dec 11, 2005 | 01:19 PM
Lauj87's Avatar
what makes it soo much of a bitch is trying to get the clamp back on tightly how it was, yeah when you put it back in, it's just like taking it it out! should be easy puttying the axle back in, just make sure its all the way in...if its not it'll pop out on yea!
Old Dec 11, 2005 | 01:21 PM
Lauj87's Avatar
make sure your useing a 6 point socket not at 12 you wouldn't wanna strip those bolts. makes it easier if you have one of those adapters that can bend, i usually use an extinsion with it to.
Old Dec 11, 2005 | 01:34 PM
ight well ill try again tomorrow im frustrated as expletive and just want to blow the damn thing up, hopfully tomorrow will be better
Old Dec 11, 2005 | 01:44 PM
txracer's Avatar
worset comes to worse, just get a new axle if you go to auto zone, you can tell them you want a brand new axle and not a rebuilt one, they take 2 or 3 days to get in at most. and are completely brand new i think mine was 94 bucks after tax and all of that
TB123
Transmission & Drivetrain
Mar 22, 2009 02:36 PM
ragejed
Nov 21, 2003 04:08 PM
MeanGreenEG9
Mar 17, 2003 06:24 PM
S13 slide
Nov 17, 2002 08:10 PM
nullbert
Apr 15, 2002 08:40 PM
