Fuel pressure question...
Old Mar 15, 2002 | 12:51 PM
Liquidx02's Avatar
Default Fuel pressure question...
Im using stock injectors on 12:1 compression with JUN III. Would 55 psi with the line on be to much? Im using a 190lph fuel pump. Is that psi to much, and what if any are the long term effects of keeping the fuel pressure that high?
Old Mar 15, 2002 | 04:32 PM
Ruby Civic's Avatar
Default Re: Fuel pressure question... (Rattlesn8ke)
increasing fuel press does not necess. mean more fuel delivery, assuming that is what you want to do, much better to play with injector pulse width. Also why establish how much press you want to run ahead of time?
why don't you start at a semi-conservative baseline, and up it gradually, checking seat of the pants response, sparkplugs, etc. if you do not have an air/fuel monitor or dyno....
Old Mar 16, 2002 | 03:11 AM
Liquidx02's Avatar
Default Re: Fuel pressure question... (Ruby Civic)
I just want to know if 55 psi with the vacumm line on is too much psi for stock injectors. Ive upgraded to a 190lph fuel pump
Old Mar 16, 2002 | 08:32 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Fuel pressure question... (Liquidx02)
It's not too high of a pressure for stock injectors. With the blower I hit high 60's all the time and have been for over a year.
More fuel pressure does mean more fuel to a certain extent. A 190 L/hr pump will start to lose fuel delivery at about 100psi.
Using bigger injectors and playing with duy cycle would be a better way to go, but on a stock ecu that would be a good trick.
BobbyRodriguez
Aug 18, 2012 12:00 AM
jaredvabeach
Aug 6, 2008 07:38 PM
Cyphear
Feb 24, 2007 01:42 PM
Red D Dragon
34
Apr 5, 2004 04:51 PM
Leo95SE
Jun 24, 2002 01:03 PM
