Leaky trunk help?
Old Dec 11, 2005 | 09:30 AM
wonton2049's Avatar
Default Leaky trunk help?
Does anyone else have this problem? I was looking in my trunk the other day and it was wet inside. I cleaned it up and then a couple days after, it was wet again after it rained. i was looking for holes or rips in the seal for the trunk but i didnt see any.
anybody know what the problem is?
i have a 98 civic ex.
Old Dec 11, 2005 | 09:35 AM
11SEC CIV's Avatar
Default Re: Leaky trunk help? (wonton2049)
taillamps usually leak
Old Dec 11, 2005 | 09:36 AM
JayDiem_k20_Dc5's Avatar
From: University of Massachusetts, Amherst, Ma, US of A
I do and I don't know where it's coming from. I gutted the trunk and back seat and on the driver side in the trunk there is a rectangular opening. Big hole, I think that's where it's coming from and leaking down into where the spare tire is! The opening is right where the rear bumper is on the right side. That's just my hypothesis.
Old Dec 11, 2005 | 09:40 AM
StreetRacinThug's Avatar
I had this problem where the lining of the rubber when you open the trunk and it was kinda of a leak that wasnt a real hole just a seal between the metal and I bought some stuff called Goop from AutoZone and put it over and under and it never leaked again(Messy stuff my advice is place a good amount of goop, wait 5 minutes and spread with fingers by pushing downto make nice and neat.
Old Dec 11, 2005 | 09:50 AM
nighttrain33's Avatar
Default Re: (StreetRacinThug)
I bought some of the "rino-liner" stuff for mine. I plan on putting it in my and then my truck if it works out ok.
-Shane
Old Dec 11, 2005 | 10:39 AM
JDM-EJ1's Avatar
Default Re: Leaky trunk help? (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">taillamps usually leak</TD></TR></TABLE>
Correct. You may want to see about replacing the tail light gasket on them.
Old Dec 11, 2005 | 11:05 AM
evade this honda's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">I bought some of the "rino-liner" stuff for mine. I plan on putting it in my and then my truck if it works out ok.
-Shane</TD></TR></TABLE>[QUOTE=JDM-EJ1] isnt that **** heavy though
Old Dec 11, 2005 | 11:13 AM
99blackcivicSi's Avatar
Default Re: (evade this honda)
have someone get in the trunk with a flashlight and you spray water on the trunk, thats the easiest way to find a leak
Old Dec 11, 2005 | 01:06 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (99blackcivicSi)
Your sunroof drain hoses are probably clogged or disconnected. Pull back the trunk lining on either sidewall of the trunk and inspect. The mult-part hose has a slip-on connection inside the trunk behind the trunk lining inside the quarterpanel. If it is clogged there, or disconnected there, which happens, any water from your sunroof drains directly into your trunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">have someone get in the trunk with a flashlight and you spray water on the trunk, thats the easiest way to find a leak </TD></TR></TABLE>
And this test doesn't work if the water is coming from the sunroof drain hoses.
Old Dec 11, 2005 | 01:11 PM
JDM-EJ1's Avatar
Default Re: (Screwtape.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape. &raquo;</TD></TR><TR><TD CLASS="quote">
And this test doesn't work if the water is coming from the sunroof drain hoses.</TD></TR></TABLE>
How exactly do you find if the drain hoses are leaking or not?
Old Dec 11, 2005 | 01:14 PM
Multi-paradigm
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
How exactly do you find if the drain hoses are leaking or not?</TD></TR></TABLE>
Well, if they are disconnected where they should be joined, that should be your first clue.
If there is some type of an obstruction after the joint in the trunk, that would be another clue.
Spray water around the sunroof area to find if the drain hoses are leaking. SPRAYING WATER ON THE TRUNK, as I said, will not work because the sunroof drain hoses don't drain water from the trunk...they drain from the sunroof.
Old Dec 11, 2005 | 05:21 PM
wonton2049's Avatar
COol. thanks for the help guys
ReVeNgEd-SoN
Aug 25, 2011 05:58 PM
foomashoo
Apr 23, 2007 08:42 PM
tkosmith
May 17, 2005 04:42 PM
BoBo Racing
Dec 22, 2004 12:14 AM
mr_mbuna
Nov 1, 2002 09:24 PM
