So I get this "P28" that does not look like one....
Old Dec 11, 2005 | 08:13 AM
No-Gi's Avatar
Default So I get this "P28" that does not look like one....
I got this yesterday. Guy told me it came from a stock civic. I opened it up and it looked like it was chipped already. I have chipped several P28's before and this one looks different. BTW, it came from a 95. Here are some pics:
Old Dec 11, 2005 | 09:48 AM
drdisco69's Avatar
Default Re: So I get this "P28" that does not look like one.... (3_South)
I have seen some "factory chipped" ecus. Looks like you got one of them. Read the chip and see what's different, for poops and hahas.
Old Dec 11, 2005 | 10:22 AM
No-Gi's Avatar
Default Re: So I get this "P28" that does not look like one.... (drdisco69)
https://honda-tech.com/zerothread?id=1460095
Old Dec 11, 2005 | 10:27 AM
mmuller's Avatar
Mad Scientist
thats as everyone is saying a stock external rom ecu.
Havent seen a p28 with external rom though.
Read it when you get it out like drdisco69 sayd.
post results
Old Dec 11, 2005 | 01:55 PM
black98gsr-t's Avatar
looks like it came out of a automatic trans civic... the three black pods in the upper left corner in your first pic.... a manual trans only has one..
Old Dec 11, 2005 | 02:12 PM
drdisco69's Avatar
Default Re: So I get this "P28" that does not look like one.... (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">black pods </TD></TR></TABLE>
Lol, the word you're looking for is "transistor". And yes, it is an auto. Not that it can't be 'cured' of that condition...
Old Dec 11, 2005 | 02:25 PM
No-Gi's Avatar
I already removed RP17
Old Dec 12, 2005 | 06:38 PM
FaceTuned's Avatar
thats a po6 11fo board non vtec yes its automatic but you could convert that to vtec and its chipped!
Modified by jdmhatchness at 7:51 PM 12/12/2005
Old Dec 12, 2005 | 06:41 PM
drdisco69's Avatar
Default Re: (jdmhatchness)
Newsflash: it's got the v-atak parts on it...
Old Dec 13, 2005 | 04:52 PM
No-Gi's Avatar
Default Re: (drdisco69)
I removed the E-prom (what whetever it is) and I think I damaged the board.
I lifted one of the wires on the board. Look closely`where I removed the 28 PIN chip.
Is this ECU any good?
Old Dec 13, 2005 | 04:59 PM
drdisco69's Avatar
Default Re: (3_South)
Ouchy. It can probably be saved, lay that trace down, and check the rest with a multimeter to make sure they're ok.
Old Dec 13, 2005 | 05:12 PM
No-Gi's Avatar
Umm. WHat do i check for resistance? between which ones?
More info please.
Thanks,
Old Dec 13, 2005 | 05:13 PM
drdisco69's Avatar
Follow the trace from the pad to the component it leads to. Make sure there's continuity between those 2 points. If there is, you should be ok. If there's not, you can run a wire "manually" to repair it.
Old Dec 13, 2005 | 05:16 PM
No-Gi's Avatar
Thanks. Ill try that in a bit. if not, what size or kind of wire should I use?&gt;
Old Dec 13, 2005 | 05:26 PM
drdisco69's Avatar
Anything small will work, you see how big the traces on the board are. Smaller wire will be easier to get in place.
Old Dec 13, 2005 | 05:41 PM
No-Gi's Avatar
The trace finally snapped off. I will solder in a piece of wire and hopefully it will work.
Thanks for all the help
Old Dec 13, 2005 | 06:04 PM
No-Gi's Avatar
I cut up an extension cord and used one of the wires inside. I checked it with the multi meter an it had continuity. I hope this does it.
Thanks a Million.
No-Gi
Dec 11, 2005 10:00 AM
^Sammy]!.
Jul 16, 2004 09:54 PM
deftones0817
Jul 6, 2004 11:41 AM
hotintegranights
Feb 8, 2004 11:47 AM
