Car overheated? is it possible that my internals are still good?
I was on the freeway and the gauge turned superhot, past the H and my check engine came on... And i pulled into my friend's shop and smoke was coming out my hood. I don't know the exact condition of my motor yet but i will find out today?
if this can be fixed, how much would it cost? i'm hoping nothing is fried up
my car overheated in the past, but this is a rebuilt motor with less then 30k
just had a recent oil change also
help me out yall
help me out yall
Well when you saw the gauge climbing up you shoulda pulled over and checked the basics such as low coolant or possibly a leak somewere... Its possible the overheating warped your internals depends how long it was like it was.
I did check my coolant, everything seemed to be fine... my gauge was acting really weird, it was fluctuating going hot, then cold, then hot again
so i thought it was an electrical problem, but turned out to overheat
sucks to be me
hopefully my friends shop doesn't charge me hardcore
sucks to be me
I am going to be working on my 99 Integra today (timing belt + water pump and head gasket)
I think my head gasket is bad because of the temp fluctuation and loss of coolant add that too the bubling coolant tank and white smoke I think its my HD compression test will prove it today,,
Well I am changing the timing belt because I am due for that service and I will be changing my Head gasket because I think that thats what is causing my overheat + loosing coolant and misfires...
its your thermostat...If you got it to cool down in high PRM's
If its stuck shut it wont let coolant take care of the engine, and heat up.
you can just touch the lower hose, and if its only warm, not hot like the top hose you found your problem.
yeah, i noticed that when i took the rpms, my guage will fluctuate to normal then back to hot
so u think its just my thermo, hopefully... i dont need another rebuilt motor
that cost me $2000 last time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 »</TD></TR><TR><TD CLASS="quote">you should be alright....might have blew out the headgasket but thats alot better then having to rebuild the whole motor again!</TD></TR></TABLE>
lets hope its not the headgasket as well..if you did. you may have warped your head too. Pull of your valve cover, check to see if its milky and check your spark plugs to see if theres oil in your cylinders
Welll I checked my compression was running 175 across the board and its running strong after figuring out my coolant leak was my heater hose and it was such a tiny pinhole leak(thank god it wasn't a head gasket). My misfires stopped too since I changed my wires + plugs, the plugs were rusted and crappy!
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Wah »</TD></TR><TR><TD CLASS="quote">I did check my coolant, everything seemed to be fine... my gauge was acting really weird, it was fluctuating going hot, then cold, then hot again</TD></TR></TABLE>
same problem. Although my radiator had a leak. the difference is I knew. When you over heat you gotta drive to a parking spot and just stop. It sounds like you drove like 15 20 minutes like this? This may not hurt the motor initially but you will have a "short" long term reliability. Perhaps.
i drove about 10 mins with the check engine light on? does this mean my engine is messed up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Wah »</TD></TR><TR><TD CLASS="quote">update: my head gasket is blown, the radiator hose is about to blow
Anyone want an 4 dr LS shell or parts off it? I am not going to fix it
damn if only you were in So Cal. I would buy the whole thing...
1995 auto LS Sedan, sorry i left that out
yeah, has all the stock parts, all the power options work, selling the car as is or parting it out...
whichever comes first
