what do I need for b20 swap???
Old Dec 11, 2005 | 05:32 AM
tranzvision's Avatar
Default what do I need for b20 swap???
I have a 90 Integra LS (obd0) w/ a cable tranny..what exactly do I need for the b20 swap?? do I need to do a cable to hydro tranny conversion? and will I lose PS or AC?
Old Dec 11, 2005 | 09:34 AM
jdmcars.com's Avatar
Default Re: what do I need for b20 swap??? (tranzvision)
All you need is the B20 long block and all/most of the parts off the orginal engine. Between your stock engine, and the B20 long block -you will have ALL the needed parts for your swap.
Old Dec 11, 2005 | 09:59 AM
Default Re: what do I need for b20 swap??? (jdmcars.com)
So all the internals and the head should fit on the b20 block w/out any modification ??
Old Dec 11, 2005 | 01:44 PM
XYU's Avatar
XYU
Ask me about vaginal warts
not sure about 1990, but for 1994+ i used everything stock from B18. i think u need to change computer from obd0 to obd1 <-- this is just my guess. Good Luck!
Old Dec 11, 2005 | 02:11 PM
redDAinteg's Avatar
Default Re: what do I need for b20 swap??? (russian rocket)
all b20's are obd2, so you would need to convert to obd0 or obd2
Old Dec 11, 2005 | 02:16 PM
nickG's Avatar
Default Re: what do I need for b20 swap??? (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">all b20's are obd2, so you would need to convert to obd0 or obd2</TD></TR></TABLE>
he wont have to convert unless he wants to..
swap everything onto the b20 and youre set..
use your obd0 dizzy and ecu and you wont have to convert...
Old Dec 11, 2005 | 02:37 PM
Default Re: what do I need for b20 swap??? (nickG)
So i'm assuming from the previous posts..that the b20 swap is a complete bolt on...as long as I use my stock ecu
Old Dec 11, 2005 | 02:55 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tranzvision &raquo;</TD></TR><TR><TD CLASS="quote">So i'm assuming from the previous posts..that the b20 swap is a complete bolt on...as long as I use my stock ecu</TD></TR></TABLE>
not quite...You will need to figure out a different way to run your PVC valve. the b18a/b run a PVC valve into the intake manifold that leads into the back of the block...but the 96+ motors run the PVC valve through the valve cover
Old Dec 11, 2005 | 04:34 PM
Default Re: what do I need for b20 swap??? (Deluzional)
ahh more things to figure out...
Old Dec 12, 2005 | 02:18 PM
is there anymore information I need for the swap???
Old Dec 12, 2005 | 02:33 PM
BrooX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tranzvision &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 Integra LS (obd0) w/ a cable tranny..what exactly do I need for the b20 swap?? do I need to do a cable to hydro tranny conversion? and will I lose PS or AC?</TD></TR></TABLE>
Old Dec 12, 2005 | 05:01 PM
Default Re: what do I need for b20 swap??? (DA9GUY-637)
does anyone know the average price for a b20 swap???
if possible can you make a list of the parts needed. thanks in advance
Old Dec 12, 2005 | 05:51 PM
rkrone's Avatar
no, it depends on the head you have on, i am running with obd1 just fine
efbastard
Feb 13, 2017 07:11 PM
90Integra_Rs
Mar 24, 2009 10:07 AM
haroldthefly91crx
Apr 21, 2008 04:50 PM
sixfiveoh
Jan 10, 2007 10:40 AM
SIK IN DA HED
Feb 13, 2004 08:40 AM
