problem w/ bored throttle body
Old Dec 11, 2005 | 04:27 AM
Mugen_DC2R's Avatar
Default problem w/ bored throttle body
i got my ITR throttle body bored to 69-70mm.
my idle is not 900rpm
some time at traffic light, the idel is 1500rpm, after i give it a rev or 2 , it goes back down to 900 rpm
Old Dec 11, 2005 | 08:32 AM
Brick Top's Avatar
Default Re: problem w/ bored throttle body (Mugen_DC2R)
itr TB 69mm? right
maybe 65mm. either u need to adjust ur throttle body
or u got a leak.
Old Dec 11, 2005 | 08:40 AM
totsie7944's Avatar
dude my R never idles right. So i wouldn't worry too much.
But I also have my head P&Ped, and the engine is fully built. What all do you have done?
for instace if you have bigger cams I am not surprised at all it doesn't idle 100% right
Old Dec 11, 2005 | 09:20 PM
Mugen_DC2R's Avatar
Default Re: problem w/ bored throttle body (totsie7944)
i have toda b's, and i port and polish the intake manifold b4 putting the bored throttle body.
it didn't have idle problem, until after i've install the bored throttle body.
Old Dec 11, 2005 | 09:32 PM
Combustion Contraption's Avatar
The throttle plate is probably sticking, other than that, youve changed airflow characteristics. You should properly reset the ECU and perform the idle learn procedure.
Old Dec 11, 2005 | 11:14 PM
rjay8604's Avatar
Default Re: (LsVtec92Hatch)
Modified hondas NEVER EVER IDLE well, lol. There is a damn curse, as long as it doesn't die on you all the time, screw it.
Old Dec 12, 2005 | 07:05 PM
scUba-stEve's Avatar
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">itr TB 69mm? right
or u got a leak.</TD></TR></TABLE>
you probably could bore an itr tb to 69mm...they have more material that can be removed, compared to a stock b16 or gsr.
DelSolMarine
Jan 17, 2011 02:16 PM
shabam
Aug 7, 2007 05:14 PM
95_red_dc
Sep 11, 2006 09:47 PM
Initial DA6
Aug 29, 2002 03:24 PM
luc_cairo
May 2, 2002 06:33 PM
