vtec problem....check out pics
Old Dec 10, 2005 | 09:34 PM
TheIceMan's Avatar
Default vtec problem....check out pics
check engine light is on.....NO VTEC...i discovered this broken wire....is this the problem and how would i fix it???
im not a genious about cars, but i no this has something to do with vtec, and the wire is broken!
Old Dec 10, 2005 | 10:07 PM
TheIceMan's Avatar
can i solder them...or do i need a new vtec oil pressure switch
Old Dec 10, 2005 | 11:13 PM
honda head's Avatar
Default Re: vtec problem....check out pics (SigleyEK)
how much wire do you got coming out of the plug?? because you might be able to solder ... oh, where is the plug located?? what color is it??...good luck
Old Dec 11, 2005 | 07:24 AM
mmuller's Avatar
Mad Scientist
take the pins out of the connector and either get new ones and crimp the wire or work the ones that you have and solder
Old Dec 11, 2005 | 09:25 AM
93civic_sedan's Avatar
yea puch the pins out and resolder
Old Dec 11, 2005 | 10:08 AM
mtber's Avatar
You could simply bypass the vtec oil pressure switch by jumping a wire from the vtec oil pressure switch to the vtec solenoid signal.
See Are X
Sep 4, 2024 03:31 PM
91 DA Revived
Oct 28, 2010 05:25 PM
jdmbreed
Sep 26, 2005 07:56 AM
Bimmerman
Jun 15, 2005 05:23 PM
