I'm a total n00b! Tach install help!
Old Dec 10, 2005 | 07:23 PM
civicEXtreme's Avatar
Default I'm a total n00b! Tach install help!
HOw do you install a tach into a 97 dx hatch? Never did it, and clueless.
Old Dec 10, 2005 | 07:32 PM
movingIIshadow's Avatar
Default Re: I'm a total n00b! Tach install help! (civicEXtreme)
Yeah I'm wondering the same thing, and also... is it possible to install a 92-95 SI cluster into a 93 DX (I'm assuming an SI cluster has a Tach, am I right?) and hook up the tach on the SI cluster in a DX? I'd prefer not to have one of those ghetto *** aftermarket tachs poking out of my dash. Thanks.
Old Dec 10, 2005 | 07:48 PM
thanks for the bump, but don't jack the topic.
Old Dec 10, 2005 | 07:53 PM
hatchi's Avatar
if you buy an ex/si cluster it is plug n play just take out the old one and put in the new one.
Old Dec 10, 2005 | 08:33 PM
john666's Avatar
black = ground
red = power
white = illumination
green goes to blue wire on driver side shock tower. It'll have a connector/plug and a cap on it usually. Or you can run it from the distributor its by a black wire with a yellow stripe (usually). or you can run it to behind the cluster i believe it was on the harness on the left blue/white
Ground the black wire to the fram.
red goes to letter E
and white goes to D
i might have the letters mistaken someplace but just test it and you will findout.
A stock cluster is plug and play.
Old Dec 10, 2005 | 08:53 PM
zccr-xsi's Avatar
Default Re: I'm a total n00b! Tach install help! (john666)
not the black with yellow strip.ITS GOES TO THE SOLD BLUE WIRE THAT YOUR TACH SINGAL WIRE!
Old Dec 11, 2005 | 07:42 AM
can this solid blue wire be found behind the cluster? So I don't have to have any stray wires under the hood.
Old Dec 11, 2005 | 08:15 AM
kyden's Avatar
Default Re: (civicEXtreme)
yes, it should be in the plugs for the cluster. there's also a connector at your drivers side shock tower.. its a blue wire with a cap on the end of it.
Old Dec 11, 2005 | 08:42 AM
Default Re: (kyden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden &raquo;</TD></TR><TR><TD CLASS="quote">yes, it should be in the plugs for the cluster. there's also a connector at your drivers side shock tower.. its a blue wire with a cap on the end of it. </TD></TR></TABLE>
if I went with the wire on the fender well, should I just use a wire tap?
Old Dec 11, 2005 | 08:43 AM
vsmferio96's Avatar
Default Re: (kyden)
just buy an ex cluster and hook up a stationary shift light inside your cluster. just lace it through the solid blue wire using an rpm pill. you tell it what to engage the light at and it looks a hella lot cleaner than some monster tach on your dash!
Old Dec 11, 2005 | 10:09 AM
I already bought a tach off a friend, and a cluster swap isn't going to work... I like to know how many miles are are on the car originally.
Old Dec 11, 2005 | 10:11 AM
Soccerking3000's Avatar
just an fyi, you can swap out the odometers
Old Dec 11, 2005 | 10:28 AM
JDM-EJ1's Avatar
Default Re: I'm a total n00b! Tach install help! (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">if you buy an ex/si cluster it is plug n play just take out the old one and put in the new one. </TD></TR></TABLE>
This is going to be the easiest and look the cleanest IMO.
Old Dec 11, 2005 | 11:06 AM
jlsmi2's Avatar
up
Old Dec 11, 2005 | 11:53 AM
mike93eh
Guest
Posts: n/a
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">just an fyi, you can swap out the odometers</TD></TR></TABLE>
why swap out odometers when you can just change the one thats in there to whatever you like?
Old Dec 11, 2005 | 01:57 PM
Default Re: (mike93eh)
cause thats no legal i dont think while swapping them is
Old Dec 11, 2005 | 02:27 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">cause thats no legal i dont think while swapping them is</TD></TR></TABLE>
why not? youre putting the exact same milage that was on there. if you lower it then it would be illegal.
hondanube2010
Jun 30, 2010 05:10 PM
ExtraBlackRex
Jun 14, 2010 03:17 AM
lancerkid06
11
Jun 9, 2007 12:28 PM
408maro
Oct 20, 2006 07:40 PM
BlkCivic97
Dec 15, 2002 05:31 PM
