5th Gen "ODB II?" location
Old Dec 10, 2005 | 03:48 PM
bigj505's Avatar
Default 5th Gen "ODB II?" location
Hey I have emission coming up soon, but my engine light is on. I have to fix the problem anyways, but this give me extra incentive. My problem is that I cannot find my plug and my manual got soaked in brake fluid. Could someone tell me where it is so I can pull the code? A pic would be great also
Old Dec 10, 2005 | 03:51 PM
SteveoBA8's Avatar
Default Re: 5th Gen "ODB II?" location (bigj505)
the obd2 aldl port where a scanner plugs in should be under the drivers side dash, /_______\ kinda shaped like that.
Old Dec 10, 2005 | 03:54 PM
Dameltajo's Avatar
passenger side under glove compartment in the left side, u will have pull the door away(it looks like its part of the carpet)its little triky just keep looking if dont find it right away (it took my about 2 hours my first time).
Old Dec 10, 2005 | 03:55 PM
SteveoBA8's Avatar
Default Re: 5th Gen "ODB II?" location (Dameltajo)
i think your talking about the jumper so he can check the code without a scanner right?
Old Dec 10, 2005 | 03:59 PM
bigj505's Avatar
Default Re: 5th Gen "ODB II?" location (SteveoBA8)
Naw, I'm talkin about the plug. AutoZone pulls codes for free, but I looked under the dash and I could not see the plug that looked like /__________\. I'm thinkin its hidden behind some panel
Old Dec 10, 2005 | 04:05 PM
SteveoBA8's Avatar
On most cars its usually under the drivers side dash somewhere easily seen, some fords and in the center console ,and so on, try downloading a fsm off the net and it will show a pic of where it is.
Old Dec 10, 2005 | 04:27 PM
92hondalude's Avatar
on 4th gen ludes its in the center consol i think
Old Dec 10, 2005 | 04:34 PM
SteveoBA8's Avatar
Default Re: 5th Gen "ODB II?" location (92hondalude)
Yes the 4th gen is behind the radio in the center console, he has a 5th gen obd2 which the aldl(assembly line data link connector) has a plug for a scanner to plug into.
Old Dec 10, 2005 | 05:02 PM
nervous's Avatar
As stated by Dameltajo, the port is behind a small panel on the passenger's side of the center console, next to the radio, under the dash. The 2 pin "jumper" connecter is also behind that panel, right next to the ODB-II port.
Old Dec 13, 2005 | 03:38 PM
Dameltajo's Avatar
did u ever found it?
B20Zer
Honda CR-V & Element
Jan 9, 2018 12:39 AM
b18crx
May 30, 2008 07:47 PM
Toe-Knee
Acura TL, RL & ZDX
Aug 24, 2006 01:22 PM
HS2G
Jul 15, 2006 06:51 PM
1gEF-8
Aug 7, 2005 10:06 AM
