Sticky Throttle Issue...
Whenever it is really cold my throttle tends to get stuck at very low RPM, between 1 and 2k... If i say cruz in 2nd or third gear and let go of the gas, it'll keep pulling at the same exact RPM, then kick out and start slowing down. But 1 to 3 seconds later......... BAM back to the same rpm and the car pulls!! WTF.. I cruzed down the street with out touching the gas, brake, clutch for over 2 minutes at 20MPH. It kept kicking in and out by it self, will not stall nothing, in gear. hahaha Any ideas WTF is going on?
Man this is really dangerous, especially if I let some one drive my car.
Thanks for the help guys!!
- Dmitriy
remove your intake to expose your throttle body. Then use some intake/throttle body cleaner which can be purchased at your local auto parts store. Start up your car then spray the cleaner into your throttle body but don't use too much b/c it might make your motor stall.....hope that helps and try seaching next time
Thanks bro! I sure did that couple months ago hoping that would fix the issued. I also did search but I guess not well enogh, there is threads like that out there?
https://honda-tech.com/zerothread?id=1433260
I did everythng xept for the thing MGAGS7 recommended. Only one problem tho... I don't think others are having same issue as me, thats the thing. Myn Opens and closes by it self... Pulls, lets go, pulls, lets go..
Hi Hater.
17
Oct 18, 2008 10:35 PM
pohaku
Oct 1, 2007 01:04 PM
