Transmission POS??
Old Dec 10, 2005 | 12:47 PM
red_honda_racer's Avatar
Default Transmission POS??
So I got a 1991 LS tranny for my GSR motor and so I start my car up and leave it in neutruel and when I try to let out the clutch to let it just idle, it trys to move and dies acting like its in gear when its impossible, at least I think. any idea guys as to what could cause this??
Old Dec 10, 2005 | 04:16 PM
Johnny_Rocket's Avatar
Default Re: Transmission POS?? (red_honda_racer)
are you positive it's in neutral? does the shifter feel like it's shifting in and out of gears? does any one gear feel different than the other?
Old Dec 10, 2005 | 07:27 PM
ricebucket's Avatar
Default Re: Transmission POS?? (JohnnyH)
forget to set the tension on the clutch cable?
Old Dec 11, 2005 | 12:07 AM
Yeah the tranny feels good going in from 1st -5th, and the clutch cable tension is perfect, reverse won't go in at all as far as I'm concerned. me and some buddies tried moving it and rocking it to see if maybe we could find nuetruel but something is fucked up cause without the clutch in, it won't move at all. I'm thinking of pulling it tomorrow and seeing if I can figure out what the cause is and if its fixable, otherwise I'm looking for a new tranny. I'll keep you you guys informed.
ps: I should of never got my tranny off of EBAY!
Old Dec 11, 2005 | 09:40 AM
jdmcars.com's Avatar
Did you "force" the tranny on when putting it up to the engine. If the transmission doesn't slide right into place, you can have the clutch out of alignment, and when you force it into place, then you are going to have a set up where the clutch never fully disengages in neutral -sounds like this might be an issue for you. -or -something in the tranny could just be done/shot.
Old Dec 11, 2005 | 10:08 AM
Default Re: Transmission POS?? (jdmcars.com)
Yeah I know for a fact that the clutch works fine, and anyone who would force a tranny on is an idiot. But I'm pretty sure the tranny is shot, damn I don't want to pull a tranny is 20 degree weather.
shoklid
17
May 7, 2009 07:56 AM
kixcrx
Dec 15, 2006 06:57 PM
cupOjo
Jul 1, 2006 07:34 AM
red_honda_racer
Dec 11, 2005 12:09 AM
blueintegra90
Feb 11, 2004 01:12 PM
