z6 head / a6 block. will a y8 head gasket be too thin?
Old Dec 10, 2005 | 09:13 AM
97grnrs's Avatar
Default z6 head / a6 block. will a y8 head gasket be too thin?
ive heard you can take the middle layer out of a y8 headgasket to raise compression even more. but i am mixing a 91 SI block (a6) with a z6 vtec head, will there be enough clearance if i use the y8 gasket without the middle layer or no? ive done it before with the stock z6 gasket but if i can squeeze a lil more power out of it by usin the y8 gasket i will.
Old Dec 10, 2005 | 09:39 AM
95dxhatch's Avatar
i just checked it on a compression calculater and that setup is only 10.2:1 youll be more then fine.
Old Dec 10, 2005 | 11:11 AM
97grnrs's Avatar
Default Re: (95dxhatch)
ya , i saw that too but i didnt know there was a way u can tell by that ratio if the pistons will contact valves.
jdmhonda123
Dec 1, 2010 10:28 PM
mattie_96
Sep 11, 2006 03:14 PM
chippy
Mar 3, 2006 03:56 AM
sinfulj32
Nov 29, 2005 06:54 AM
ej8
Apr 17, 2003 06:34 AM
