D15B into '96 Civic EX, backfired, now no spark.
Old Dec 10, 2005 | 09:01 AM
Attoir's Avatar
Default D15B into '96 Civic EX, backfired, now no spark.
Just finished a swap putting a JDM D15B into '96 Civic EX.
Using OBD2 injectors, D15B dizzy rewired to work w/ OBD2.
It had been running, but poorly. Rough, sounded like it was missing. I tried to start it up this morning so I could troubleshoot some more, and it started, running rough as usual. It let out a real loud backfire, and died. After that, I couldn't get it to start again. Could not get spark, have swapped out ignitors on the dizzy, have triple checked all grounds (Thermo, tranny, and valve cover, right?) and still no spark.
I've taken off the cap and felt the coil w/ my finger, and did not get shocked when motor turned over. So I guess dizzy is getting no power for some reason.
Cliff notes:
Loud backfire, car dies, now no spark.
SOMEONE GIVE ME A LIST OF THINGS TO CHECK FOR, PLEASE!
Old Dec 10, 2005 | 11:36 AM
Attoir's Avatar
Default Re: D15B into '96 Civic EX, backfired, now no spark. (Attoir)
Up, need help guys.
Old Dec 10, 2005 | 11:46 AM
kyden's Avatar
if it's obd2.. get a scan tool on it
Old Dec 10, 2005 | 11:49 AM
Attoir's Avatar
Default Re: D15B into '96 Civic EX, backfired, now no spark. (kyden)
converted to obd1
Old Dec 10, 2005 | 01:31 PM
civic_90_08's Avatar
hey man...maybe you should sale it to me...lol
Old Dec 10, 2005 | 08:45 PM
dewoine's Avatar
Default Re: (civic_90_08)
bump for my homboy he needs to get this car out his shop
Old Dec 10, 2005 | 10:32 PM
Contender25
Guest
Posts: n/a
Um...did you're timing being off ever come into mind?. I hope it's right, via TDC on the block and head, and ignition.
Old Dec 12, 2005 | 07:29 AM
dewoine's Avatar
Default Re: (Contender25)
bump!!
Old Dec 12, 2005 | 08:01 AM
drtyhatch's Avatar
sounds like the dizzy is dead and or you have some spark plugs on wrong.
Old Dec 14, 2005 | 12:06 AM
Contender25
Guest
Posts: n/a
Yeah if he knows it's good then he needs to go for his timing cause it's pretty damn important. If it IS you're dizzy then it must be extremely old/bad and fucked up or altogether, or you are running abnormally richer then average to burn it out quicker.
Old Dec 14, 2005 | 01:31 AM
The_Todd's Avatar
Farts in the shower
What do you do when your car doesn't start...you check for spark and fuel.
Have you done either?
By just putting your finger on the cap while the car is fired wouldn't really constitute "testing" in my book. Get yourself an voltometer and test that coil .
Drambo94
36
May 31, 2015 05:49 PM
Smoked_Peasant
Apr 9, 2014 10:32 AM
SpleenBoy
Nov 3, 2011 05:00 AM
Puscifer
Jul 28, 2010 01:12 PM
Attoir
Dec 10, 2005 02:25 PM
