zex plugs"?
Old Dec 9, 2005 | 08:39 PM
nekoabandoned's Avatar
Default zex plugs"?
how much of a difference do u feel from these SUPER TURBO GAPED PLUGS(with new rice flavoring)compared to normal plugs?
d16z6 turbo 9 psi
Old Dec 9, 2005 | 08:49 PM
574-240sx's Avatar
I stick with NGKs and gap them down when I turn up the boost. I use to occasionally run into spark blow out when I turned the boost up. If anything I would save your money and run a step cooler NGKs.
Old Dec 9, 2005 | 08:58 PM
Default Re: (574-240sx)
ngk R are what is in my engine now,just bought the zex ones last night because i crushed 2 of them doing a compression test while they were out of the engine they had a run in with by tool box CRUSH!
so i just wanted to hear some opinions on these (SUPER!)plugs that i just payed for
Old Dec 9, 2005 | 10:15 PM
honda138's Avatar
zex plugs suck!
Old Dec 9, 2005 | 10:19 PM
_gurusan_'s Avatar
Default Re: (honda138)
Stick with NGK.
Zex makes decent SOHC cams...and some good n2o system. That's about it
Old Dec 10, 2005 | 12:10 PM
97spooncivic's Avatar
Default Re: (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda138 &raquo;</TD></TR><TR><TD CLASS="quote">zex plugs suck!</TD></TR></TABLE>
true that. they dont even make good nitrous plugs. They fricken melted in my brothers car. POS
NGK
Old Dec 11, 2005 | 12:23 AM
Default Re: (97spooncivic)
....bump for more input!
Old Dec 11, 2005 | 04:14 AM
Default Re: (nekoabandoned)
....bump for sleep
Old Dec 11, 2005 | 04:45 AM
sicky's Avatar
grammer nawzi
ngk
Old Dec 11, 2005 | 08:47 AM
YiNYaNg's Avatar
Default Re: zex plugs"? (nekoabandoned)
Zex & Bosch +2 & +4
Due to the design the spark gets blown away to easy.
Old Dec 11, 2005 | 08:51 AM
YiNYaNg's Avatar
Default Re: zex plugs"? (H-T)
Best spark plugs are NGK iridium & Denso iridium
but denso's has a .4mm tip where NGK has a .6mm tip
Old Dec 11, 2005 | 10:05 PM
Ace0246's Avatar
well if i could find the pics i would show you what some Zex plugs did to the rod bearings in my Turbo ZC engine. It was tuned OK, but a split plug is a BAD IDEA in any Honda. BTW, it wasn't MAJOR damage. The crank was fine, however I do feel that had I made a smarter choice about plugs (like using an NGK plug, 1 step colder), there wouldn't have been a problem.
Pullig
Jan 26, 2005 04:53 PM
hondaeg8
Sep 26, 2004 11:46 PM
Drew Peacock
Oct 21, 2003 10:25 PM
civictypenos
Oct 2, 2002 09:27 PM
