Ls/Vtec hood clearence with EG6?
I have a 93 Eg6 with a VIS c/f hood, I just put in a Ls/Vtec (b16 head) and I cannot fit my hood back on. Any one know if I need a new hood or if I can just cut the skeleton on my hood? Any help would be great. Thank you.
* B A N N E D *
Re: Ls/Vtec hood clearence with EG6? (EG6R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R »</TD></TR><TR><TD CLASS="quote">your engines not sitting right</TD></TR></TABLE>
unless the aftermarket hood has deeper reinforcment that stock.
-cut that **** but be careful.
Re: Ls/Vtec hood clearence with EG6? (EGmikeH22)
does your stock hood fit? if not i dont think your engine is sitting right. how, i dunno. but try trimming the skeleton and see if that helps
Imperious: Mod of Valor
Re: Ls/Vtec hood clearence with EG6? (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">does your stock hood fit? if not i dont think your engine is sitting right. how, i dunno. but try trimming the skeleton and see if that helps</TD></TR></TABLE>
I concur.
I concur.
Re: Ls/Vtec hood clearence with EG6? (vexx7001)
I've seen plenty of straight forward swaps that have rubbing issues with the skeleton and the valvecover. To say the motor isn't sitting right w/out seeing any pics, isn't really a solid statement.
I don't know what gen VIS hood you have, but here's someone that had a similar problem: https://honda-tech.com/zerothread?id=572161
Re: Ls/Vtec hood clearence with EG6? (rodrez.)
i had the same problem with my vis cf hood and my ls vtec...i just spaced my hood with some spacers and called it a day!
Thanks for your help. I have all three hasport integra mounts on my car. I think i'll just cut the skeleton. I don't own a stock hood it's hard to say if it will fit. I don't reall like the lifted hood look I'm more about being a sleep this why I'm painting my c/f hood the same color as my car. But thank you for your help again.
85mm LS VTEC
03-19-2005 04:38 AM
