check engine light flashing?
Old Dec 9, 2005 | 04:34 PM
tannerhoops's Avatar
Default check engine light flashing?
I have a 96' integra gsr w/a drag turbo setup tuned w/ vafc and running 10psi and I still have the obdII conversion. I was driving the other day coming home from work and I ran it hard that morning because I was running late and I raced an sti on the freeway and went all the way in 4th which I don't normally do. but on my way home I heard a almost knocking sound coming from the engine and my check enginge light was flashing, I don't know what that means, and my car sort of smelt like gas my wife said "spray paint". The car still runs and moves but I don't want to drive it in this condition. Everything was professionally installed by Tuners Edge in N.N. VA but the just recently shut down so if anybody can give me advice or info that would be greatly appreciated
Old Dec 9, 2005 | 06:19 PM
Runnerdown's Avatar
Default Re: check engine light flashing? (tannerhoops)
The check engine light flashes when something major is wrong. You said it has OBD2 correct? I have never seen or heard of obd1 flash. Misfire condition/codes will cause that....sounds like possible detonation damage.
Old Dec 10, 2005 | 04:54 AM
Chiovnidca's Avatar
Usually caused by a dead misfire. Which cylinder died?
Old Dec 11, 2005 | 07:13 AM
Default Re: check engine light flashing? (Chiovnidca)
what is a dead misfire exactly? How do I fix that? Would I still be able to drive with a dead cylinder because my car is still drivable.
Old Dec 11, 2005 | 07:18 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerhoops &raquo;</TD></TR><TR><TD CLASS="quote">what is a dead misfire exactly? </TD></TR></TABLE>
A cylinder that's not running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerhoops &raquo;</TD></TR><TR><TD CLASS="quote">How do I fix that? </TD></TR></TABLE>
Depends on what the problem is: Electrical, fuel or mechanical.
03djmAccrd
15
Sep 25, 2010 04:33 PM
dc2long
Oct 21, 2006 04:46 PM
B18Redline
Apr 7, 2004 08:01 AM
dynomax27
Oct 31, 2002 05:46 PM
DeeperFOLK
Oct 11, 2002 01:36 PM
