what size tire do i need?
Old Dec 9, 2005 | 03:13 PM
watsvtecEK's Avatar
Default what size tire do i need?
i just got some gt3's and there 15x7 and i want to know what tire i need.
could i use 195/50/15 or should i get 205/50/15. also i am thinking the first number is the width of the tire, am i right? what will be good for a 7" width?
thanks
Old Dec 9, 2005 | 05:01 PM
watsvtecEK's Avatar
Default Re: what size tire do i need? (b18tegra)
bummmp
watsvtecEK's Avatar
is this a realynoob question or somthing? im sorry but i dnt realy know much about tires...
Old Dec 10, 2005 | 11:12 AM
KOALA YUMMIES's Avatar
They will both work, the 195/55 might be slightly stretched but 205/50 will work very well. Ive used a couple different 205s on 7" wide wheel and it was always a good fit.
Old Dec 10, 2005 | 01:05 PM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18tegra &raquo;</TD></TR><TR><TD CLASS="quote">i just got some gt3's and there 15x7 and i want to know what tire i need.
thanks</TD></TR></TABLE>
Well, you don't say what type of car you're driving but I'm going to guess it's a more recent model Teg. If that's the case, I'd suggest going with the 205's. They'll keep you closer to stock gearing than the 195's and there are a tons of good tire options out there. If this a street only car, then the Kumho 712 is a cheap and decent tire. If you're looking to autoX the car some and aren't going to have a seperate set of wheels/tires for racing, then I'd look at either the newer Azenis or the Kumho MX.
Best of luck
Christian
Old Dec 10, 2005 | 02:17 PM
B18C5 EH's Avatar
The 205's will be perfect, not too stretched (195's on a 7"), and not sloppy (215 series on a 6") if your car has aftermarket suspension with a lower ride height or if you ever go to that, then they are not too wide to rub either.
As far as street tires go I like the Bridgestone Potenza S-03 Pole Positions, not as inexpensive as Kuhmo's, but not too much more. It's all personal opinon and preference though.
Tire Rack has a survey and review of each tire they sell.
Old Dec 11, 2005 | 12:09 AM
watsvtecEK's Avatar
Default Re: what size tire do i need? (B18C5 EH)
i have a 93 ls, bought 195/50, i got a killer deal.
Old Dec 11, 2005 | 05:30 AM
Xian's Avatar
Try 205/50's next time. IMO, they look better and with the extra section width the give you alot more contact with the road (especially with some of the "oversized" 205 options out there).
Old Dec 11, 2005 | 05:42 AM
ace0fspades's Avatar
Default Re: what size tire do i need? (Xian)
I have a 2002 Honda civic LX, and I'm trying to put 16's or 17's on it. What tire size should I get for that?
Old Dec 11, 2005 | 12:35 PM
watsvtecEK's Avatar
Default Re: what size tire do i need? (ace0fspades)
it matters how wide the rim is. and what kind of quality you want. maby 205/45/16? or 205/40/17.
Old Dec 11, 2005 | 04:33 PM
Xian's Avatar
I'd suggest 15x7 b/c of better tire availability, better ride, and performance compared to 16 & 17's. If you're certain that you have to get large wheels, then either of the previously mentioned tire choices should work well.
Old Dec 13, 2005 | 10:28 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what size tire do i need? (D 2da A9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 ls, bought 195/50, i got a killer deal. </TD></TR></TABLE>
That's too small. You really want to get 195/55-15 or 205/50-15. Most tires in either size are approved for 15x7 rims.
Here is how the outer diameters of those sizes compare with stock:
195/60-14 (stock)
195/50-15 -2.3 percent
195/55-15 +1.0 percent
205/50-15 -0.6 percent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace0fspades &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2002 Honda civic LX, and I'm trying to put 16's or 17's on it. What tire size should I get for that?</TD></TR></TABLE>
Your car has larger stock tires than Integras, so you need to get 205/50-16 or 205/45-17. If you only go to 15's, get 195/60-15.
185/70-14 (stock)
195/60-15 +0.1 percent
205/50-16 -0.5 percent
205/45-17 +0.3 percent
Old Dec 13, 2005 | 03:32 PM
SpoolnEG6's Avatar
Default Re: what size tire do i need? (nsxtasy)
nsxtasy gave both of you the right info. For future reference Tire Rack's website is excellent for deciding on what tire size you need for what size rim you are stepping up to. Just plug your year,make, and model and your ready to choose
Old Dec 13, 2005 | 04:49 PM
watsvtecEK's Avatar
i just got them instaled on my rims and they fit fine. not streched or anything, they must be bigger 195's. they look sick!!!!
Old Dec 13, 2005 | 04:51 PM
watsvtecEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">That's too small. You really want to get 195/55-15 or 205/50-15. Most tires in either size are approved for 15x7 rims.
195/60-14 (stock)
185/70-14 (stock)
205/45-17 +0.3 percent</TD></TR></TABLE>
what do you mean by the %'s??
Old Dec 13, 2005 | 04:54 PM
SpoolnEG6's Avatar
what do you mean by the %'s??</TD></TR></TABLE>
That is what percentage the tire is smaller or larger than the factory size the vehicle came with
Old Dec 13, 2005 | 05:37 PM
watsvtecEK's Avatar
Default Re: what size tire do i need? (SpoolnEG6)
i had when i bought the car 15x6 with 195's. so not much of a change..
Old Dec 13, 2005 | 06:42 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i had when i bought the car 15x6 with 195's. so not much of a change..</TD></TR></TABLE>
The tread width is the same. But with the 195/55-15 size, the outer diameter is slightly larger, and is what you want.
GsR-Freak
Apr 14, 2005 04:42 AM
808State
Jan 30, 2005 12:48 AM
vtec_yosh
Feb 9, 2004 12:48 AM
combustion
Nov 6, 2003 07:21 AM
Vanilla4215
Jun 9, 2002 08:57 PM
