I REALLY NEED HELP WITH MY CLUTCH
IT HAS BEEN LEAKING BROWNISH TYPE OF LIQUID INSIDE THE CAR UNDER THE CARPET...I REALLY NEED HELP ON WHAT I SHOULD DO OR WHAT IS WRONG WITH IT..WHEN I PUSH THE CUTCH PEDAL DOWN IT DOES NOT COME BACK UP UNLESS I PULL IT...MAYBE THE SEAL IS BROKEN BUT I DO NOT KNOW IF IT IS THE MASTER CYLINDER THAT IS LEAKING OR THE SLAVE.....PLZZZ HELP IF CAN.... THX FOR READING.
That could be either the Clutch or Brake Master Cylinder (both in the same vicinity). Because you've got an additional issue, I suspect it's the Clutch master Cylinder that's giving you fits.
P
P
definately a clutch master cylinder needs replacing...
P_ ole buddy the brake master would not leak inside the car, the booster has a lip on it so brake fluid can no longer get inside the booster and ruin it ,, if brake master leaks it would show below master cylinder on firewall
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">...another entry for the notebook. believe it or not, I was thinking of non-power assist brakes. Go figure
P</TD></TR></TABLE>
Yo P-- u are showing your age amigo
P</TD></TR></TABLE>
ozh_hawaiian
Dec 3, 2011 03:28 PM
I Like Hondas
Mar 20, 2006 10:25 AM
