Building H22A5 NA engine.
Old Dec 9, 2005 | 11:50 AM
Root79's Avatar
Default Building H22A5 NA engine.
The H22A5 1997 year is strange engine, it have mix of everything. There are square type intake springs, LMA's are springs, the rods have free-flow piston finger bearings. The piston instalation was very easy on this rods. Lot of things that never seen on other H22A/2/4 engines. Never open H22A1.
Car originaly is 4 gen lude with H23A2 engine. The main bearings melt after oil pump failure. With AC, Cruise, no 4WST, that's good, less weight.
We get this engine with strange noise inside. The seller warn us about that. So, we wait for everything.
The everything was overheated piston, burned ex valves, wear out rocker arms and camshafts. Here story:
https://honda-tech.com/zerothread?id=1412770
As it was so bad, we decide to go serious.
"JePistons" 11.5 compr. with stock rods.
"CP" piston fingers
Removed balanced shafts
Auto to manual tensioner
3 angle valve job, port correction by "Laki Tuning"
Sleeves by Kolbenshmidt, Germany.
OEM gasket kit
Pics by my padre D3
The basic mods which will give the second life to this engine and more power.
Head:
More pics to come. Any ideas of more mods welcome!
Modified by Root79 at 11:42 PM 12/9/2005
Modified by Root79 at 1:22 PM 12/10/2005
Modified by Root79 at 1:01 AM 12/24/2005
Old Dec 10, 2005 | 06:22 AM
Root79's Avatar
Default Re: Building H22A5 NA engine. (Root79)
No balance shafts:
Old Dec 23, 2005 | 01:48 PM
Root79's Avatar
Run this engine on dyno.
Tune it with Crome Pro.
Denso platin 20(heat) spark plugs.
Stock cams, soon upgrade with Crower stage 3 and valve train.
60.3mmX1.5mm stainless steel exhaust, tig welded.
First pull after street tune:
Little fuel and ignition correction at top end:
This is one of my first experiences in ecu tune.
Modified by Root79 at 1:19 AM 12/24/2005
Tad
Dec 27, 2017 11:30 AM
celliott92
Oct 22, 2014 04:45 AM
f1 vtec
May 30, 2006 08:27 AM
garados
Jan 20, 2004 05:33 PM
N1Spec
Oct 20, 2002 08:06 PM
