CAI question
Old Dec 9, 2005 | 09:23 AM
ImXposed's Avatar
Needs $$ for a Hooker
Default CAI question
Would an AEM CAI for a GSR fit my 95 LS? Perhaps with modification? Let me know ASAP.
Old Dec 9, 2005 | 09:29 AM
purplegsr's Avatar
Default Re: CAI question (ImXposed)
No, the intake manifolds place the throttle body at different locations. The GSR manifold is lower, so it has an extra bend that won't agree with an LS setup. It's not worth it to chop up the piping and remove the bend, but you could save the AEM filter and buy generic piping on ebay for your LS.
Old Dec 9, 2005 | 09:31 AM
ImXposed's Avatar
Default Re: CAI question (purplegsr)
damn thats ... eh well. maybe another sweet deal will come along. Thanks for the info.
Old Dec 9, 2005 | 11:52 AM
SlammedDC2teg's Avatar
Yes it would. Ive done it before. on my boys cars. It will be a tight fit but it will work.
Old Dec 9, 2005 | 11:54 AM
93_teg_CT's Avatar
Default Re: CAI question (SlammedDC2teg)
Just buy an ebay intake arm for 10 bucks and a K&N filter at auto zone for like 20 bucks.
Old Dec 9, 2005 | 12:06 PM
ImXposed's Avatar
Default Re: CAI question (93_teg_CT)
so it really doesn't matter all that much if its a name brand intake, pretty much anything will work the same right? anyone else got opinions or info about the gsr cai fitting a 95 ls?
Old Dec 9, 2005 | 01:46 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">so it really doesn't matter all that much if its a name brand intake, pretty much anything will work the same right? anyone else got opinions or info about the gsr cai fitting a 95 ls? </TD></TR></TABLE>
The GSR has the dual stage intake manifold, so the throttle body is in a different location. I believe, certainly not sure though, that a type-r cai might work.
And the only reason to worry about brand name is for smog. If you don't have to pass a visual inspection, then you don't need a brand name. There might be a power difference from the coating the big names use, compared to a generic one, since its supposed to help prevent heat soak, but I doubt it would be enough of a difference to worry over for anyone except the drag racer who needs that last 0.01 second.
Old Dec 9, 2005 | 01:56 PM
purplegsr's Avatar
Default Re: CAI question (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">The GSR has the dual stage intake manifold, so the throttle body is in a different location. I believe, certainly not sure though, that a type-r cai might work.</TD></TR></TABLE>
The ITR and the LS have the same TB location, so they are interchangeable. If you go get a gsr CAI, it will probably fit if you angle the piping into the sleeve that attaches to the TB somehow, but I wouldn't want to worry about it. Changing the angle of the piping or modifying it so it fits could mess up the airflow that AEM based their design on, so if you're going to change it, might as well get a generic one and save your money.
Also, you will have visual to pass CA smog, so it's good to have an AEM CAI with a carb # that matches the make, model, and trim of the car you have. I don't think the LS and GSR AEM shares a carb eo number - search for the CA state California Air Resource Board Executive Order page - so you can search for the EO# for both and see if they match.
Old Dec 9, 2005 | 05:27 PM
tany integra intake will work.
BrOkEn_Dc2
Dec 27, 2006 01:17 PM
integGSR805
Feb 12, 2005 04:52 AM
jamessh1
Jul 14, 2003 03:58 PM
unknown317
Jan 22, 2003 07:04 AM
millertime
Sep 11, 2001 06:51 PM
