just did a compression test r these good numbers?
doin some checking just to be safe
turbos acting funny so i desided give her a good tune up and such.and the fact that vtec still not kicking in(basturd!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urname7698 »</TD></TR><TR><TD CLASS="quote">They look good. All are within 5% (150-158). Having any troubles or just doing some checking?</TD></TR></TABLE>
They look pretty good. Consistency is key, unless they're like 10 12 11 14 across the board. Then you're fooked.
They are a bit low though. Did you do the test at WOT? I had numbers like that in my Y8 when I didn't, and then retested and got 205 across the board.
They're a little low. It's supposed to be 184 psi.
The minimum is 135 psi, and the max variation is 28 psi
All per the factory service manual
Mike
Mike
I thought the numbers could vary depending on the kind of tester used?
At least that's what I've heard. I remember hearing about people that used one tester, got 150-ish across the board, then used a different one and got 190-ish across the board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">
No, consistency is NOT the key. Maintaining all within a certain tolerance is the key. Jesus people, get off the consistency crap, please.
</TD></TR></TABLE>No, consistency is NOT the key. Maintaining all within a certain tolerance is the key. Jesus people, get off the consistency crap, please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
No, consistency is NOT the key. Maintaining all within a certain tolerance is the key. Jesus people, get off the consistency crap, please.</TD></TR></TABLE>
I have been misinformed. My apologies.
IVAN93EG
15
Jul 23, 2006 02:46 PM
AbitAvenger
30
Oct 6, 2005 07:50 AM
89 crix si
Aug 1, 2005 09:47 AM
Dr. Gonzo
Mar 3, 2002 09:30 AM
