compression test results - d16z6
Re: compression test results - d16z6 (AbitAvenger)
As long as you are getting #s similar across the cylinders, its in good health. ie: 10% deviation is ok as a general number.
Re: (New Dimensions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by New Dimensions »</TD></TR><TR><TD CLASS="quote">better than mine with 80k miles on it
150
135
175
175</TD></TR></TABLE>
looks like your rings blew or headgasket
150
135
175
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (islandtechengineers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by islandtechengineers »</TD></TR><TR><TD CLASS="quote">185? your strong and good...</TD></TR></TABLE>Hell yeah, especially with 170K
Unceasing Measure
Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">hello water pump, head gasket, timing belt, and 7 psi </TD></TR></TABLE>
And ARP head studs if you want it for more than a week.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">And ARP head studs if you want it for more than a week.</TD></TR></TABLE>
Any other suggestions? Precautionary measures?
Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">Any other suggestions? Precautionary measures?</TD></TR></TABLE>
Imperious: Mod of Valor
Re: compression test results - d16z6 (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">sounds like good numbers</TD></TR></TABLE>
Re: compression test results - d16z6 (JDM-EJ1)
hi, i just checked my compression and i got 205-210 across all four cylinders... is this right?!! i have the same engine... d16z6... thanks
Re: compression test results - d16z6 (banzaiMiyagi)
Yeah that's good. Seems a bit high but every gauge is slightly different.
It's more about the variance between the numbers...and of course if they are surprisingly low it should be looked into.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzaiMiyagi »</TD></TR><TR><TD CLASS="quote">hi, i just checked my compression and i got 205-210 across all four cylinders... is this right?!! i have the same engine... d16z6... thanks </TD></TR></TABLE>
You probably have carbon build up on your pistons if it's that high stock.
I tested my stock d16z6 with 100k on it right after I changed the head gasket and cleaned the pistons off and I got 200 accross the board.
Re: compression test results - d16z6 (dorkoftheyear)
so build up of carbon is ok right? as long as the compression is good.. its all good! now im ready to boost?!
Carbon build up is not good. It can cause detonation among other things, and it's a sign of an engine problem.
Re: compression test results - d16z6 (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Mine all measured at 105 psi when I did a compresion test on the little bastard yesterday. </TD></TR></TABLE>
Woah. Something is definitely wrong. Did you have the throttle wide open when you did it?
Re: compression test results - d16z6 (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ »</TD></TR><TR><TD CLASS="quote">Woah. Something is definitely wrong. Did you have the throttle wide open when you did it?</TD></TR></TABLE>
Nope nothing wrong at all. Low compresion ratio, big cam and a gauge that reads on the low side instead of high like most do. Measured leakdown at 2%-5%.
Heres a quick breakdown on how a compression test works...
take atmospheric pressure (14.7 lbs) x whatever your compression ratio is (saaay.. 10:1) and your results should be roughly 147 lbs across the board AT SEA LEVEL. The end result varies depending on your elevation.
If any of your cylinders vary by (plus/minus) 10% then you have a problem in that/those cylinders.
185lbs is fine.
185lbs is fine.
