HELP: Just put in new motor and....
Old Mar 15, 2002 | 02:16 AM
CivicEK.PDX's Avatar
Default HELP: Just put in new motor and....
I just swapped in my new motor. Anyways...I pulled it out to take it for a spin.....and I get down the block...shift into 2nd and it stops working. Also now that it dont move....when I step on the gas the speedo kinda climbs also. SOMEONE PLEASE HELP . Thanks
Old Mar 15, 2002 | 02:44 AM
kenji's Avatar
25 Year Member
Default Re: HELP: Just put in new motor and.... (CivicEK.PDX)
If the speedo is working and the car does not want to move when you press the gas with the car in gear you might have a problem with your differential.
Please keep in mind that it is difficult to diagnose problems via the internet. This may not be what is happening in your case. But, from past experience the symptoms you described indicate something wrong with your diff.
Good luck.
-kenji
Old Mar 15, 2002 | 05:25 AM
1 2 NV's Avatar
sounds like the axles r not in the tranny housing all the way. speedo climbs indicating that the diff is movin but the car isnt. axles axles axles.
Old Mar 15, 2002 | 06:00 AM
Kamin's Avatar
Default Re: HELP: Just put in new motor and.... (hondaatwsu)
do you hear a grinding noise? if you dont and the spedo is working an axle probably popped out.
Old Mar 15, 2002 | 02:05 PM
DAMMIT........it was the axle.....pulled it and it was sitting out about 1.5 inch. About 2mm was taken off the inboard part. Diff looks fine( found some metal shaving.......but wiped them out......but it looks fine) just the splines on the axle are gone about the ring. Waiting for axle right now.....and gonna give the tranny a fluuid change.
Old Mar 15, 2002 | 02:18 PM
Kamin's Avatar
TOLD YOU!
j/k
good to know you found the problem.
Old Mar 15, 2002 | 04:01 PM
Default Re: HELP: Just put in new motor and.... (KAMiN)
Thanks
batto24GSR
Sep 7, 2012 09:42 AM
Oreo-TeCk
Jul 1, 2007 10:33 PM
memorybox
Nov 23, 2006 05:08 PM
steronz
Apr 5, 2005 02:41 PM
JDM Like Whoa
18
Dec 24, 2004 05:51 PM
