replaced mounts but shifter still moves when i hit gas or decellerate.
i replaced the front two mounts and the rear on my 93 del sol S but i still feel the shifter move front and back when i accellerate or decellerate. it feels like it moves more than it should , and i wanna fix this problem before i put my swap in it cause if this crap 1.5l motor does it my new swap will prob rip it out. .why else would the motor have play like this? its not loose but it def moves some. before i replaced the front mounts the car would buck like crazy when i tried to downshift so i know they were bad cause it dont do that no more but it still does this.
If you are going to do a swap ( B Series) than I would just get a set of HASPORT mounts to eliminate the issue there is also a company that offers and adapter to eliminate the "Sloppy Shifter Issue" Will have to find the name for you!!!
ya, it cant be designed to move that much. not wit new mounts. i ordered prothane inserts for torque mounts and rear mount so hopefully it will help
the shifter is supposed to move a little bit. you are saying it moves during acceleration, not just jiggling around on its own. this is normal and getting the bushings for the engine and shifter just to get rid of this is not worth it. it makes your whole car shake...trust me...i want my stock ones back.
themunchkinman
Apr 5, 2008 04:37 AM
