d series mounts
hey guys last year i broke a couple axles due to shitty mounts and my engine torquing all the time, besides those shitty poly urathane inserts are there any alternatives to solid mounts? thanks
buy some factory mounts and fill them with 3m window weld. window weld works way better than those mount inserts, and doesnt make your car unstreetable. do a search there is a writeup about the window weld idea. its what is in my car right now and i have no complaints except for the expected more noticeable vibration.
whats wrong with the poly inserts?? if you want your motor solid they are great...just kinda hard to get that rear mount on but yeah your car does vibrate a lot more....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">hey do you have any more information on these?? ie where to get them etc
, thanks</TD></TR></TABLE> http://jimfab.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill »</TD></TR><TR><TD CLASS="quote">whats wrong with the poly inserts?? if you want your motor solid they are great...just kinda hard to get that rear mount on but yeah your car does vibrate a lot more....</TD></TR></TABLE> The rear is a bitch to remove, but this one makes it easier for future removals since the mount has a flat surface so with a standard wrench you could remove it without dropping the rear crossmember all the way. The car vibrates more at idle, but the engine doesn't torque under acceleration. If your rear suspension is soft it will actually dive for the floor under hard acceleration with this in place
, thanks</TD></TR></TABLE> http://jimfab.com/ <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill »</TD></TR><TR><TD CLASS="quote">whats wrong with the poly inserts?? if you want your motor solid they are great...just kinda hard to get that rear mount on but yeah your car does vibrate a lot more....</TD></TR></TABLE> The rear is a bitch to remove, but this one makes it easier for future removals since the mount has a flat surface so with a standard wrench you could remove it without dropping the rear crossmember all the way. The car vibrates more at idle, but the engine doesn't torque under acceleration. If your rear suspension is soft it will actually dive for the floor under hard acceleration with this in place
are you running all 4 engine mount inserts?
2 from ES and 2 from prothane.
i think it was:
ES for F and R
Prothane for L and R
i run all 4 on my dohc zc. and its pretty Solid
i think it was:
ES for F and R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LamRacing »</TD></TR><TR><TD CLASS="quote">are you running all 4 engine mount inserts? </TD></TR></TABLE> Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">yes all 4 and didnt like it at all, still far too soft, i want like b series into ef solid type mounts</TD></TR></TABLE> If you can find someone who sales the side mounts, I'm down. But until then I think are only option for solid is the front and rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> If you can find someone who sales the side mounts, I'm down. But until then I think are only option for solid is the front and rear.</TD></TR></TABLE>
I believe prothane makes inserts for all 4 mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">I believe prothane makes inserts for all 4 mounts</TD></TR></TABLE> NO! Solid mounts like the ones I showed in my picture, I have solid front and rear mounts, no inserts, no window weld, actually solid mounts. I wish could find someone selling actual solid side mounts, that way I don't have to worry about inserts or what not.
yeah exactly, well ill talk to my buddy tomorrow, he makes copys of b series in to ef mounts so i dont see why i couldnt give him some d series ones to make into completely solid ones
