94 INTEGRA RS ENGINE BOGGING MISSFIRE PLEASE HELP ANY IDEAS ANYONE????
I HAVE A PROBLEM WITH MY 94 INTEGRA RS ITS BOGGING MISSFIRES THRUOUT ALL GEARS I HAVE REPLACED MY ENGINE BLOCK/HEAD BECOUSE I THOGHT IT WAS A COMPRESSION PROBLEM AND MOUST OF THE SENSERS O2 SENSER ECU FULE FILTER EVAPO CHARCOAL CANESTER VAC LINES FUEL INJECTERS ONLY THING I DIDNT REPLACE IS THE DISTRIBUTOR AND THE FUEL TANK/PUMP ECT.. AND ITS STILL BOGGING ANY ONE KNOWS HOW TO FIX THIS PROBLEM PLEASE LET ME KNOW ASAP?
THE PUMP IS GOOD BECOUSE WHEN I LEFT THE FILTER BOLT LOSE IT SPRAIED A STREEM 4FEET HIGH DO YOU THINK IT COULD HAVE SOMTHING TO DO WITH VACUM OR THE EVAPO SYSTEM?
try the tps sensor(throttle position sensor). when mine went out it would cut out off and on. also the basics like spark plugs, spark plug wires, and all the engine grounds. i had left a engine ground off a swap i did on accident once and it ran fine for half an hour but then all of the sudden started cutting out and dying. sometimes it's just the little things that cause big problems. good luck.
triton318
May 22, 2011 04:51 AM
thecivicman
Mar 23, 2008 08:14 PM
