cooling capacity of 95 accord
Hello, i live in a very cold climate, and i am trying to get a good amount of coolant in my car so it wont freeze at night (est. low tonight -9) anyways i just added about 1/4 to 1/3 of a gallon this afternoon i just was wondering how much i need in there to be sure it wont freeze.
thanks
Danny
thanks
Danny
i usually mix mine 50/50 coolant water. if the radiator was just drained it holds about a gallon but -9 is pretty cold. does the antifreeze container have any kind of mixing chart on it. if it does you may mix it that way. im glad i dont live where you live.
It holds about 2 gallons, from what i've read on mine. If what is already in the radiator and engine is at least a 50/50 mix you should be alright. But if there was nothing but water in there, 1/3 of a gallon is not enough. You need to get a tester (not expensive, and you can get one just about anywhere) to find out for sure. Have you drained and filled it before? What mix did you use?
The 5th Generation Accords carry 1.82 US Gallons in the Cooling System.
Assuming the recommended 50/50 mix ratio; you'd start putting 0.90% Gallon Antifreeze (If you're THAT ****) and fill the rest with water.
Most Honda purists throw a Gallon of Antifreeze in it, the rest water and call it a day.
P
P
I was speaking in terms of total capacity (sorry) (it's been an EXTREMELY long day
The Drain and Refill volume runs about 1.43 US Gallons. (According to Owners Manual)
Hummm
Looks like almost all comes out with the Baby (so to speak)
P
).The Drain and Refill volume runs about 1.43 US Gallons. (According to Owners Manual)
Hummm
P
measure the strenght and see how clean the coolant looks if it is too weak, drain radiator get a 50/50 mix anti-freeze and water, loosen up the bleeder screw at t-stat housing, fill radiator till coolant comes out of bleeder , close bleeder, top off radiator ,,, let car run till warm, so coolant circulates, after it sits a bit, remove cap and retest coolant strenght if stil too low, drain some from radiator and put just coolant do not mix it this time ...rebleed system..
dman81
Mar 7, 2005 10:19 AM
