cars bogging at 700 to 1000rpm range on a LSVTEC
it's a high compression motor lsvtec w/ctr pistons..motor runs strong but doesent idel good... idels kinda low and then it kinda boggs with it....it boggs when your slowly taking off on first gear after 1500rpm then it seems fine...i dunt kno if thats how the motor suppose to be like.....
i kinda think it could be either feul or electric , i have a b&m fuel pressure regulator i set the fuel at 45psi on normal idel, i dunt kno where it's suppose to be on a LSVTEC set up...?? motor sounds like it's running on 3 pistons only when your taking off on first gear, but all pistons giving out pretty good compressions 285-295psi...could it be the head leaking??? lmk....
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">if i were you i would take my car to a competent tuner then</TD></TR></TABLE>
yes sir
yes sir
Kevin Mcvay
Mar 27, 2016 04:59 AM
