d16z6 tranny vs d16y8 tranny
Old Dec 6, 2005 | 08:44 PM
tobe1424's Avatar
Default d16z6 tranny vs d16y8 tranny
which two of those ex transmission have shorter gear ratios? need to know asap
Old Dec 6, 2005 | 08:54 PM
Turbo_y8's Avatar
Default Re: d16z6 tranny vs d16y8 tranny (tobe1424)
i belive the y8
Old Dec 6, 2005 | 09:04 PM
underb00steg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">i belive the y8</TD></TR></TABLE> ..i dont think so ....theyre almost identical but the z6 is slightly closer i believe..
Old Dec 6, 2005 | 09:08 PM
.Beaver's Avatar
Bloody Beaver
Default Re: d16z6 tranny vs d16y8 tranny (underb00steg6)
my y8 tranny reved about 200rpm higer on the highway, if that helps any
go search
Old Dec 6, 2005 | 09:17 PM
tobe1424's Avatar
Default Re: d16z6 tranny vs d16y8 tranny (Leeroy)
ok in you guys y8 at what speed do you switch gear..1 2 3 4?
Old Dec 6, 2005 | 09:18 PM
Turbo_y8's Avatar
i dont ever really look, i just look at rpm's here and there most my shift are 2800-3000 but i dont even look anymore i just shift, after a while youll hear what sounds right, but when on the freeway at 65 on mine im around 3000
Old Dec 6, 2005 | 09:20 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leeroy &raquo;</TD></TR><TR><TD CLASS="quote">my y8 tranny reved about 200rpm higer on the highway, if that helps any
go search</TD></TR></TABLE>
Is this with an aftermarket tach? The stock tach can be off by as much as 400 RPM in the top end RPM range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">ok in you guys y8 at what speed do you switch gear..1 2 3 4?</TD></TR></TABLE>
I change from 1st to 2nd at about 35, 2nd to 3rd about 54 and I don't remember after that. I know that at 90 mph in 5th I'm at 4000 RPM even.
Old Dec 6, 2005 | 09:24 PM
Turbo_y8's Avatar
Default Re: d16z6 tranny vs d16y8 tranny (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
I change from 1st to 2nd at about 35, 2nd to 3rd about 54 and I don't remember after that. I know that at 90 mph in 5th I'm at 4000 RPM even.</TD></TR></TABLE>
you take the rpm's that high every shift, by the time im doing 35 im bombing 4th
Old Dec 6, 2005 | 09:28 PM
.Beaver's Avatar
Bloody Beaver
same stock tach same speed etc.... theres no reason that it'd be off comparing it against itself.
Now if I was comparing a stock tach to an aftermarket tach it'd be a different story
Old Dec 6, 2005 | 09:34 PM
tobe1424's Avatar
o...anyone know what mph you go from 3rd to 4th..are you sure about 2nd to 3rd at 54?
Old Dec 6, 2005 | 09:36 PM
Turbo_y8's Avatar
yea 2nd to 3rd at 54 is a little high, but seeing his other shift points it prolly strung out
Old Dec 6, 2005 | 09:43 PM
bmoua's Avatar
dont know...about 1,2,4,5 but my 3rd tops out at 83-84mph...
ALLMOTOR EK
Jun 20, 2007 06:53 PM
ME SO FST
34
Jan 28, 2005 10:49 AM
H.A.R.T b16a1crx
11
Sep 11, 2004 09:01 AM
legoman
11
Aug 29, 2004 09:36 PM
95cxhatch
Jan 6, 2004 08:04 AM
