dizzy spark problem
Old Dec 6, 2005 | 08:02 PM
menappi's Avatar
Default dizzy spark problem
k im not getting any spark from my dizzy. everything is wired correctly, sometimes right when i start it starts up (hence it must be getting some sort of spark) then dies right away. after that it wont start up and repeat unless i disconnect the battery or remove the dizzy. wiring from dizzy to ecu is fine, dizzy is good, battery is good, plugs/wires, everything is good. im thinking its something coming from the ignition. is the ignition connected to the dizzy? something is tellin me it has to do with the black/yellow wire from the dizzy. any ideas???
Old Dec 6, 2005 | 10:35 PM
menappi's Avatar
ne1?? ttt
Old Dec 7, 2005 | 12:46 AM
Fusion G2 Civic's Avatar
Try checking the grounds on your thermostat housing, also the spade terminals in your ignitor. Also try removing your gas cap, sometimes your motor creates a vacuum in the tank and this relieves this. If that doesnt work I dont know what to tell ya
Old Dec 7, 2005 | 12:55 AM
menappi's Avatar
Default Re: (Fusion G2 Civic)
what do u mean the spade in my igniter?i just put the dizzy in my friends car and it started up fine? should i still check it??
Modified by menappi at 1:56 AM 12/8/2005
jdmshawn95
Feb 7, 2011 12:15 PM
mardoiii
Nov 22, 2008 12:31 PM
JDMflavor_EJ
Jun 2, 2007 08:52 PM
AznBlueBoy
Sep 8, 2006 08:21 PM
