Do USDM ITRs use lug-centric (not hubcentric) wheels?
Old Dec 6, 2005 | 06:49 PM
Surewin's Avatar
Default Do USDM ITRs use lug-centric (not hubcentric) wheels?
I was reading in the thread...
https://honda-tech.com/zerothread?id=1014136
That the ITR 5-lug pattern uses lugcentric wheels. Is this correct?
Does the front/rear hub look different then the typical Civic hub?
Modified by Surewin at 10:28 PM 12/6/2005
Old Dec 6, 2005 | 07:18 PM
Bbasso's Avatar
Default Re: Do USDM ITRs use lug-centric (not hubcentric) wheels? (Surewin)
Lug centric - When the wheel is centered by the bolt holes/ lug nuts of the wheel, rather than by the center bore. Lug centric wheels should be balanced from the bolt holes.
Is that what you wanted?
Modified by ossabB at 11:36 PM 12/6/2005
Old Dec 6, 2005 | 07:28 PM
Surewin's Avatar
Default Re: Do USDM ITRs use lug-centric (ossabB)
So does the ITR have lug-centric wheels?
What does the hub look like? Will aftermarket hubcentric wheels work?
Old Dec 6, 2005 | 07:38 PM
Bbasso's Avatar
Default Re: Do USDM ITRs use lug-centric (Surewin)
With the rotas SS's the hubs are bigger then stock wheels so they become lug centric, But to be honest... I have not installed a set of stock wheel in a long time so I can't recall 100% but I think they use the hub to center themselves.
Old Dec 6, 2005 | 07:42 PM
migs's Avatar
Factory ITR wheels are HUBcentric. Even most aftermarket wheels come with hubcentric rings to accomodate a larger bore wheel to fit the ITR.
Typically, lug centric wheels are found on GM's
Old Dec 6, 2005 | 08:03 PM
.Ash's Avatar
Lugcentric as in my old mr2 (or gsx) where the lug slides into the wheel?
Old Dec 6, 2005 | 08:04 PM
Bbasso's Avatar
Default Re: Do USDM ITRs use lug-centric (migs)
Mike, thanks for clearing that up.
Old Dec 6, 2005 | 09:24 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Factory ITR wheels are HUBcentric. </TD></TR></TABLE>
Anyone whos changed their wheels should know that one.
Old Dec 6, 2005 | 11:08 PM
migs's Avatar
Default Re: (.Ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash &raquo;</TD></TR><TR><TD CLASS="quote">Lugcentric as in my old mr2 (or gsx) where the lug slides into the wheel?</TD></TR></TABLE>
This is called a Shank design. Its odd, if you look at this design closely. You would think it is LUGcentric. However, even with the shank design, the wheel bore will match the hub diameter.
Mitsubishi and Toyota use this design frequently as well.
Old Dec 7, 2005 | 12:20 AM
B18C5's Avatar
Default Re: (migs)
LOL. Yeah, if one of those was lug centric you'd never be able to get the wheel on!
In that thread I don't know where they got the impression that ITR rotors are lug centric though. You can lead a horse to water, but you can't teach it new tricks.
Old Dec 7, 2005 | 07:20 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (.Ash)
I don't think so (but someone can correct me if I'm wrong - hey, I admit that I'm not the most technical guy here ).
Lugcentric vs hubcentric depends on whether (a) the center bore of the wheel (that's the big hole in the very center of the wheel) fits onto the hub and that is used to center the wheel (that's hubcentric) or (b) there is no flange on the hub for the wheel to sit on, and only the lugs are used to center the wheel (that's lugcentric). As migs noted, the stock ITR wheels and hubs are HUBcentric.
Your question sounds like you're asking about lug NUTS vs lug BOLTS, which I'm pretty sure is a different question entirely. I'm sure you understand the difference between nuts and bolts. Some cars, like the ITR, have lug NUTS to fasten the wheel onto the car. The car has studs (another name for what are basically NUTS) which stick out from the hub. You slide the wheel over the studs and fasten it by screwing lug NUTS over the ends of the studs. Other cars, like most BMWs, have lug BOLTS to fasten the wheel onto the car. You slide the wheel over the hub and fasten it with lug BOLTS which screw into the hub. Both cars are HUBcentric, but one has lug NUTS and the other has lug BOLTS.
HTH
Old Dec 7, 2005 | 09:02 AM
Black R's Avatar
25 Year Member
technically, usdm itr's can use lugcentric or hubcentric wheels - per the topic question. and technically, they do use both lugcentric and hubcentric designs in the same oem wheel.
however, we typically characterize the itr as having hubcentric wheels stock.
aftermarket, there are very few wheels that meet this criteria, so we use lugcentric instead (sometimes using hub rings as well).
Old Dec 7, 2005 | 09:15 AM
.Ash's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
HTH
Both the mr2 and gsx use nuts like the itr or any other Honda. The difference is a part of the nut goes into the wheel; I was curious if this had any centering properties. I know the difference between nuts and bolts; my POS 850 has bolts.
Old Dec 7, 2005 | 11:03 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (.Ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash &raquo;</TD></TR><TR><TD CLASS="quote">The difference is a part of the nut goes into the wheel</TD></TR></TABLE>
I don't understand what you mean by that...?
Old Dec 7, 2005 | 11:05 AM
.Ash's Avatar
I'll try to dig up some pictures after I write a couple more papers.
iHEARTMYCiViC
May 6, 2012 11:29 AM
Khmerican
May 14, 2008 03:25 PM
Petah
Apr 14, 2003 12:05 PM
stumpyf4
Nov 21, 2002 11:33 PM
Mikeveli
10
May 25, 2002 06:44 PM
