cleaning the pcv and intake manifold
Old Dec 6, 2005 | 10:24 AM
idriveadelsol7's Avatar
Default cleaning the pcv and intake manifold
do i need to replace the pcv vavle or can i just spray some carb cleaner and soak the thing in seafoam or something instead of replacing it?
as for the intake manifold...can i spray in throttle body/manifold cleaner into it? or must i take the thing off and clean soak it?
Old Dec 6, 2005 | 10:26 AM
dmxsoulja3's Avatar
Default Re: cleaning the pcv and intake manifold (idriveadelsol7)
the PCV is like 10 bucks, get a new one. There are different ways you could do the intake manifold but if you want it perfect take it off, and while your at it get like a hondata intake manifold gasket or something.
Old Dec 6, 2005 | 10:49 AM
92civichatch1's Avatar
Default Re: cleaning the pcv and intake manifold (dmxsoulja3)
man get a new pvc valve they are 3 dollars 4 at most.
Old Dec 6, 2005 | 11:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 &raquo;</TD></TR><TR><TD CLASS="quote">man get a new pvc valve they are 3 dollars 4 at most. </TD></TR></TABLE>
there's 2 of them correct? a joint and a vavle?
Old Dec 6, 2005 | 11:17 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
No, there should be only one.
Old Dec 6, 2005 | 11:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">the PCV is like 10 bucks, get a new one. There are different ways you could do the intake manifold but if you want it perfect take it off, and while your at it get like a hondata intake manifold gasket or something.</TD></TR></TABLE>
what othre gaskets are there?
Old Dec 8, 2005 | 11:29 PM
dmxsoulja3's Avatar
If I were doing it I would get the intake manifold gasket and TB gasket and take the TB apart and clean it while its off the car, clean/ replace the FITV and IAC as well since it will be easily accessible.
TunerShark
10
Feb 28, 2007 10:39 AM
civic_36
Jul 7, 2006 07:18 PM
thisisntjared
17
Oct 7, 2005 07:39 PM
gawath
Sep 8, 2005 07:12 AM
Garrett
Jul 20, 2003 11:44 AM
