will ecu keep car from starting?
Old Dec 6, 2005 | 06:17 AM
96 EX's Avatar
Default will ecu keep car from starting?
alright heres whats up, blew my y8 dropped a y7 in didnt get the ecu cuz we broke the cam out of the y8 head(which we were swappin) so now i got the whole y7 in and its all together how it should go. I got good spark oil fuel ect... turns over but wont actually start. could it be that the y8 ecu is throwing codes and preventing it from starting? i know i need to get the other ecu but i figured itd at least start up. please help...
Old Dec 6, 2005 | 07:41 AM
JDM-EJ1's Avatar
Default Re: will ecu keep car from starting? (96 EX)
What codes is it throwing?
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX &raquo;</TD></TR><TR><TD CLASS="quote">alright heres whats up, blew my y8 dropped a y7 in didnt get the ecu cuz we broke the cam out of the y8 head(which we were swappin) so now i got the whole y7 in and its all together how it should go. I got good spark oil fuel ect... turns over but wont actually start. could it be that the y8 ecu is throwing codes and preventing it from starting? i know i need to get the other ecu but i figured itd at least start up. please help...</TD></TR></TABLE>
The Y8 ecu will look for the VTEC oil pressure switch and solenoid, as well as a knock sensor. I'm not sure if that will prevent it from starting...
Old Dec 6, 2005 | 07:55 AM
Soccerking3000's Avatar
Default Re: will ecu keep car from starting? (BauleyCivic)
did you check the timing after the swap? if its way off its not gunna start.
Old Dec 6, 2005 | 07:56 AM
93turbo16's Avatar
It should start the car. Make sure you have all the vacuum lines connected and the timing is on the money.
Old Dec 6, 2005 | 09:57 AM
GetawayInMoscow's Avatar
Default Re: (93turbo16)
We started my jdm b16 with a stock CX ecu and it started right away and idled okay.
Old Dec 6, 2005 | 10:09 AM
darkcvc's Avatar
Blue Sedan Crew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
The Y8 ecu will look for the VTEC oil pressure switch and solenoid, as well as a knock sensor. I'm not sure if that will prevent it from starting...</TD></TR></TABLE>
none of these will prevent the car from starting
get all the codes its throwing..you can get these without starting it...using a jumper
it most likely is not the ECU...
Preluda1992
Aug 11, 2018 12:05 AM
CivicSmith
52
Jun 30, 2015 05:16 AM
Ekevans08
Dec 12, 2012 06:11 AM
chickenwing
Oct 26, 2008 05:05 AM
j-rome
12
Jul 28, 2008 08:27 AM
