How do I correctly wire a Dead Switch?
What to i connect the switch too? Will fuel pump work? If it will i can just get a 12 V switch at more amps then the pump fuse amps. The just put it in series right? Where is a good location for this on a 89 CRX Si? Thanks a lot guys
if you just leaving it for 10 days, then take the spark plug wires with you and the battery. As for the fuel cut, do a search i think it has been posted before.
-take the ECU out
-pull the fuse for the ECU under the hood
-pull wires and even cap and rotor if u want
-get the fuel cut off switch(sorry not really sure how to do it...buddy did mine)
-if u got a club or autolock use it....dont for get the alarm if u have one
-and if u wanna go extreme....put your car on some stands and take the wheels off
-lastly...cross your fingers and pray your car is there when you come back...
good luck
good luck
