Crank Fluctuation Crap Question...
Old Dec 5, 2005 | 09:48 PM
2-logicl's Avatar
Default Crank Fluctuation Crap Question...
Okay I did do a search and found several threads hinting at what I think is the answer I was expecting but want to make 100% sure...
I have a 00 si and am swapping out the 1.6 for a gsr block...
The GSR block I got was a 94 OBD1 ownage.
Anyhow I was in the process of switching the crank fluctuation sensor over from the b16 since I still have the OBD2 ECU and well when I was taking off the timing belt sprocket off the crank it got stuck so I was gently prying up on it to pop it free... and it broke.
Honda quoted me $88 bucks for this piece BUT I still have the GSR timing belt sprocket...
I plan on running uberdata in a p28 thereby converting to OBD1
Basically was wondering should I just go ahead and use the GSR's sprocket and do the ECU conversion now (since the OBD1 ECU's don't look for the crank fluctuation sensor). Or will I still need this?
Old Dec 5, 2005 | 10:03 PM
cptengineer's Avatar
Default Re: Crank Fluctuation Crap Question... (2-logicl)
you got it. obd1= no crank sensor/gear
Old Dec 5, 2005 | 11:46 PM
2-logicl's Avatar
Default Re: Crank Fluctuation Crap Question... (cptengineer)
outstanding so chock up another couple hundred bucks..... that i don't have... CC is about maxed out!
what ecu should i run?
I heard that you can convert a p06 to a p28?
Old Dec 5, 2005 | 11:48 PM
takes two of them I belive
Old Dec 5, 2005 | 11:51 PM
2-logicl's Avatar
two of the ecus? So that you can run the dual overhead cams?
nothing_shocking
Oct 5, 2011 09:00 AM
EF9_TryMe
Oct 18, 2010 10:32 AM
gustavito1986
Apr 6, 2008 08:52 AM
teddy_dc2
Oct 4, 2007 07:54 PM
JDM96SpecCTR
Mar 5, 2005 11:03 AM
